250-500cc VForce Delta 2 Reeds - How to Remove Center Reeds?
Discussion in '2 Stroke' started by Husky 2002WR250, Oct 10, 2015.
  1. Husky 2002WR250 Husqvarna
    Rochester Hills Mi
    Have my reed cage out now and all screws out to remove outer reeds. How do the inner plate reeds come out?
    Don't want to damage but do they pop out or can the entire center section pop out?
    From 2002 WR250
  2. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Pop the center.section out backwards.
  3. Husky 2002WR250 Husqvarna
    Rochester Hills Mi
    Awesome! Great help here!
  4. Husky 2002WR250 Husqvarna
    Rochester Hills Mi
    Is there any light gap allowed? I have a very small light gap in the corners of the middle pedals - all 4 sides when viewed from inside the cage. Should it be no light can be seen? I have issues starting now and this is the last possible root cause after tearing apart the TMX. Running too rich adjusted float way down and pilot now at 25.
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    seeing daylight means the reeds are starting to get tired, but the float and pilot will have a great effect on starting.
