TE/TC VHM head and vforce 4 te300
Discussion in '2st' started by Mobil1, May 10, 2017.
  1. Mobil1 Husqvarna
    Wr 250 2003
    Got some new parts on my 17 te300.
    Can ride a gear higher and still enough power, really happy with the result.
    Vforce 4 and vhm 26.5cc head.
    Husky_250, dartyppyt and juicypips like this.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Dude that ktm looks sweet!
  3. Mobil1 Husqvarna
    Wr 250 2003
    Received the invoice today for the sxs skidplate, now wait till it arrives...
    Jon from sxs is a great guy to deal with...
  4. jsromeo288 Husqvarna
    510smr TE300 701 @2smoke_romeo ig
    Yea got mine a couple weeks ago it's great! I only wish it was easier to get on an off like the factory skid plate, the sxs takes a few Allen keys.
  5. Romanzeley Husqvarna
    smr450
    super clean.let us know how you like that v force
  6. KennyMc Husqvarna
    Placentia, California
    '16 FE 501-S
    '17 KTM 300XC-W
    Any idea what it did to your compression? I put the RK Tek head on my '17 300XC-W and I got a 29psi increase but it was setup to still run on pump gas. Works great.
  7. ride200mi Husqvarna
    AZ
    2015 TE300
    2010 Kawasaki KX250F
    Did this same thing. Although I'm using a Slavens head and V Force 4. Had to rejet 2 or 3 steps on the main and pilot. Great bottom end and pulling power for the Enduros I race here in AZ!
  8. Mobil1 Husqvarna
    Wr 250 2003
    Mounted the head and vforce at the same time so cant tell the exact diffrence each one makes.
    Std the bike was already good, now it is even better... more torque and power everywhere.
    The VHM is made for running 98octane fuel , it got 1cc less the std.
    They make inserts to your specifications on request.
    Did not test compression, squish was within spec for the VHM.
  9. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    So... what was it?
  10. Mobil1 Husqvarna
    Wr 250 2003
    VHM says 1.9mm squish.
    Set mine @2mm to be safe...
  11. Motosportz CH Sponsor
    I know Jon, great guy and very fast too.
  12. Picklito Husqvarna
    Washington
    That's interesting, as it's a little wider than a typical "head mod." Sounds like it works so just a technicality.
  13. Mobil1 Husqvarna
    Wr 250 2003
    Squish also makes a diffrence on how the power feels...
    Full race engines like i use to build for the f1h20 championship we used 0.9mm squish. Did the same with my homebuild yamaha 70ces engine.
    You can order a custom insert to achive the same compression ratio but with smaller squish instead of the 1.9mm...
