125-200cc voltage regulator
Discussion in '2 Stroke' started by Travis Thompson, May 24, 2013.
  1. Travis Thompson Husqvarna
    1991 wxe 260
    1978 yamaha xs750 special
    Im putting a headlight on my bike and ordered a regulator off ebay cause didnt have one. It keeps blowing the headlights right after i start it. Can i test the regulator?
  2. bdl507 Husqvarna
    New Hampshire
    99 wr360
    rd350 dr650 tt500 pe250 hondas lots
    Use meter chk voltage at headlight wires rev the bike up and see what the voltage is.
  3. Travis Thompson Husqvarna
    1991 wxe 260
    not sure if im doing it right but on the back of it theres 2 tabs coming off which I put the power into and then hook headlight coming back out of other one. its on my wxe 260
  4. Travis Thompson Husqvarna
    1991 wxe 260
  5. cooper Husqvarna
    Kent UK
    wre125
    The headlight bulbs are only 12v hence them blowing when its started. you should have between 12-14v on idle and under load
  6. cooper Husqvarna
    Kent UK
    wre125
    Also the regulator you got, is it just a regulator or a reg/rec?
  7. bdl507 Husqvarna
    New Hampshire
    99 wr360
    I usually use single wire snowmobile regulators they just hook to a power wire and bolt to a ground. They are available in 6v and 12v a lot of shops have them in stock.
  8. Travis Thompson Husqvarna
    1991 wxe 260
    i think its just a rectifier. I looked it up on h0alls and thats whats it called but i cant find a regulator anywhere. i have a reg/rec off an old atv i might try to get to work
  9. Travis Thompson Husqvarna
    1991 wxe 260
    I still cant figure it out. I have a blue, black and yellow wire coming from stator. My rectifier looks like this http://www.ebay.com/itm/1991-Husqva...Parts_Accessories&hash=item20bcc3667a&vxp=mtr if anybody can help me get this worked out it would be greatly appreciated. Im not sure where each wire goes on rectifier and how to wire up headlight correctly
    I would like to be able to add battery cause plan on putting dual sport kit on. Is there a reg/rec that i can buy to make this work thanks
  10. K.Forte' Husqvarna
    Any great singletrack trail..
    2010 WR 125R
    2004 Honda CRF 302X
    Travis call dale mazorow his company is called Trick Dualsport he makes the best dualsport kit on the market today IMO,he can answer your questions about your problem,,remember its a holiday so he might not answer just leave a message.. 1 661 268 1094 or dale@trickdualsport.com.. Tell him Kelly sent you...Great luck to you!!!
  11. cooper Husqvarna
    Kent UK
    wre125
    you could always get a wre wiring loom and reg/rec Travis, they weren't available in the U.S. but there are loads of wre bits on ebay germany
  12. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    I think BDL has it right, just get an AC regulator, the lights will work fine on AC voltage about 13acv. That rectifier you have is simply converting AC to DC voltage and still needs to be used in conjunction with a regulator. Sometimes in older systems that didn't have a lot of excess wattage production over what the bike uses, would just have a battery to control the voltage spike.
    bdl507 likes this.
  13. Travis Thompson Husqvarna
    1991 wxe 260
  14. gots_a_sol Husqvarna
    Charles Town, WV
    WR177
    17 250RR
    I have that TT reg/rec on my bike, works great.
