250-500cc W300 clutch cable routing
Discussion in '2 Stroke' started by Pinittowinit, Jan 25, 2011.
  1. Pinittowinit Husqvarna
    Kailua Hawaii
    I got my Glenn Kearney 300 yesterday!! What a firecracker!! Only issue is the clutch cable seems to bind a bit. Can someone please provide me with the EXACT cable routing. Thanks and aloha
  2. frankrock363 Husqvarna
    New Jersey
    My cable goes from clutch lever down between upper and lower triple clamps to right side of frame as it goes down moves around front of frame to the left where it goes behind the water pump hose then makes a big bend to cable holder on engine case. Hope that helps you can google some wr300 pics of new bikes and you can kinda se what I'm talking about.
  3. Pinittowinit Husqvarna
    Kailua Hawaii
    Thanks as it turns out it routed correctly except for where the number plate mounts on the top. It was going under so I put it over. But I feel stupid because the real problem was it just needed a little lube. Smooth as butter now.
  4. frankrock363 Husqvarna
    New Jersey
    Yes I find I have to lube my cable often but as long as I do it works well.
