water in fuel filler
Discussion in '610/630' started by mekanik, Jul 17, 2011.
  1. mekanik Husqvarna
    Kootenays, Canada
    I had to fuel the old '11' Te630 after/during a heavy rainfall and when I popped off the fuel cap, a large amount of water went into the tank! apparently it pools around the cap, how does everybody deal with this engineering marvel? I don't want lay the bike on it's side so it can drain!
  2. willie Husqvarna
    NS Canada
    TE 630
    I have noticed the same problem. Mine has water in the recess every time I gas up. If you remove the cap slowly and wipe around the recess with a paper towel you will get most of it. I add a small amount of gas line antifreeze every now and then as with all my fuel tanks to get rid of any water in the gas. Seems like water collects no matter how careful you are.
  3. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    I've spent a lot of time riding in heavy rain and have never had this problem. Mine drains right through the overflow hose. You can even hear it gurgling out when I wash the bike.
  4. RDTCU Husqvarna
    '11 630SMS
    It should be noted that not all 630 tanks came with a second drain tube (in addition to the tank vent with the check valve)
    The original tank on mine had a screw plug where the cap drain hose would exit the tank, and you would have the problem described. I had a small fuel leak around the fuel pump and the tank we swapped on had the extra drain nipple and hose.
    Look at the front of your tank and see if you have the extra nipple above the fuel pump or if it's capped with a stainless screw....
  5. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    I have the extra nipple. There's one on my tank as well. :D
  6. mekanik Husqvarna
    Kootenays, Canada
    mmmm, nipples, but no extra ones. The dealer confirmed this is a known problem although no known fix other than carry methyl hydrate when it rains or when you wash the bike!
  7. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    Why can't you just remove the plug and call it good? Or get a screw on fuel cap like I did.
  8. willie Husqvarna
    NS Canada
    TE 630
    Removed the plug with a 4 MM hex wrench. Located about 2 in below the tank vent on the left front side of the tank. Lip around filler cap will drain properly now! Don't know why some 630s have the vent and some not.
  9. Gardezy Husqvarna
    Canada
    Which type of fuel cap are you using nothing will thread in?
