250-500cc Water in oil...still
Discussion in '2 Stroke' started by wait4me, Nov 13, 2013.
  1. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    I'm about to have a conniption fit. Got water in oil. No one local had the seal so I went to a seal and bearing house and got a double lipped seal with the same dimensions and polished up the spacer. Water in oil. So I order from dealer the Husky seal and spacer, put it in and WATER IN OIL. I didn't even start it. I purposely did not put oil in it filled the radiator and left it overnight. Pulled the oil drain and out came about 1/2 to 3/4 of on ounce of water. It would probably have been more but with the cap on it would pull a vacuum. Anywhere else they can get water in trans? It is an 11 wr300 with about 100 hours. It runs great but does seem to smoke a lot when started for a minute or two. But the plug doesn't look like it has water. :banghead:
  2. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Are you installing the little oring that goes behind the impeller on the shaft?
  3. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    I am installing the o-ring between the spacer and bearing. (kinda fits into the end of the spacer/sleeve) Did I forget one?
  4. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Yeah that sounds like it. I did mine a year ago and had water in the oil after replacing everything. Took it back apart and the oring was gone. I must have torn it reassembling it. I installed an o-ring from a master link and it's worked fine for a year.
  5. Long_Stroke Husqvarna
    Logan, Utah
    2011 WR300, 2013 WR144, 2020 FE501s
    1996 DR350, 2002 Aprilia Caponord
    Did you repeat the drain procedure again? Just to be sure it wasn't just residual water in the transmission? When I put my impeller back on the shaft I tightened it as best I could with a pair of channel-locks and a rag to protect the fins. I didn't put very much force on it after hearing that they're kind of fragile. I suppose that if it weren't tight it could leak around the spacer o-ring.
  6. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    I didn't even put oil in it. I filled with water and left it overnight. Pulled the drain plug out the next day and water came out, about 1/2-3/4 of an ounce. I then pulled the small clutch cover and clutch and pressurized the cooing system and could watch the coolant drip from the shaft. I put a 14mm seal in it now and it is all sealed up. I don't know how long it will last, but it is easy to check the spacer. Someone on TT said I put the seal in backwards, that the curved metel side goes towards the water. I would swear that it didn't come apart that way, but maybe that is why it failed so early.
