All 2st Water pump impeller removal
Discussion in '2 Stroke' started by Tzedz, Sep 1, 2015.
  1. Tzedz Husqvarna
    1995 WR 360
    cbr 600
    Im trying to remove the waterpump impeller on my 95 360 Husky as i think the either the o ring or the seal behind has gone awol.So after looking at some sugestions on the forums,its seems as though ive to turn the impellor clockwise as its on left hand threads,now ive tried this and it just spins even in gear,any ideas?
  2. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    does it spin free like nothing holding it back, if so probably something broken
    if it feels like it has drag, could be bum threads?
  3. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    They do get pretty corroded especially if it's an OE part from 95. I can't remember if it's a reverse thread but l chucked it into gear and locked the rear wheel with a pole so as l can undo the impeller - had to replace the whole lot anyway.
  4. Tzedz Husqvarna
    1995 WR 360
    cbr 600
    The impeller is spinning freely,no drag at all,im thinking somthings broke inside,unless somone knows differently,if this is the case is it possible to lean the bike on its side to remove the clutch cover without draining the oil.Cheers for replys great source of info.
  5. Up-tite Husqvarna
    Why remove clutch cover, drain rad fluid and remove WP cover.
    Later george
  6. Tzedz Husqvarna
    1995 WR 360
    cbr 600
    Im thinking the problem lies behind the Clutch cover case,maybe the impellor shaft is broken,theres only one way to find out.Rads already drained
  7. ohmygewd Husqvarna
    Aprilia RSV1000
    If the water pump aint working, when you start the bike up, take the rad cap off and rev the thing, the water level should rise or swirl...if it doesn't then there is a blockage or the water pump has seized.
    Before pulling things apart, just to the simple test and you'll be on the right path.
  8. Tzedz Husqvarna
    1995 WR 360
    cbr 600
    Does anyone know if the gear on the impellor shaft is supposed to be fixed/threaded onto the shaft or is it an interference fit,as mine is spinning freely and not turning the impellor as i thought,if it is an interference fit is there any shimming that i could do?
      File size:
      79.5 KB
      35
      File size:
      81.1 KB
      32
      File size:
      71.7 KB
      30
