250-500cc wave style rear disc
Discussion in '2 Stroke' started by 454x, Oct 5, 2012.
  1. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Does any body make a wave style rear disc for the 250/300 that is not a floater?
    Tim.
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    dont you like the husky 2T rattle timbo?! google it im sure i saw one somewhere the other day. maybe ebay store of r&d husky or trooper lu in OZ. just make sure you're sitting down for when you see the price. ill stick to the rattler i think. not sure if the 4T discs would swap over or not(different hubs maybe on newer models, older 4T were the same). can you not use 'packers' or rubber washer type to stop the noise which i assume is your gripe, maybe the style too?
  3. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Based here in the UK http://www.racediscs.com/ I have used them many times all with good results
    The Husky rear items are supplied with c/s bolts that do away with the built in rattle :naughty:
    Just ordered a rear to fit on my spare wheel, the ones I fitted to my TM still looked new after 4 years of hard work
    MOTORHEAD likes this.
  4. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I just ordered one for my WR. Heck of a deal. Thanks for sharing.:thumbsup:
  5. Xcuvator Husqvarna
    Scholls Oregon
    yes
    That is resonable for sure, even the shipping. I knd of wish I needed one....
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    thats a pretty good deal. cost $100 for an aftermarket(average quality-not braking brand) disc here in OZ. nice work johnnyboy. will be buying from them when im due for front & rear discs which aint too far away. at least they should be decent quality not cheap crappy chinese steel! chalk up another one for CH :)
    454x likes this.
  7. NeoGeniX Husqvarna
    the Netherlands
    I can definately recommend racediscs, cheap and look great! Other brands costs almost double!
  8. 454x Husqvarna
    Dunnigan,Ca.
    your right, I cant stand the rattle or the solid rotor.Have no use for it.
  9. 454x Husqvarna
    Dunnigan,Ca.
    Thank you, thats what I'm talking about !
  10. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Fitted mine yesterday, no rattle and all works as it should
  11. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Looks good. Hope mine gets here soon, I can't wait to try it out.
  12. Flyin Husqvarna
    Northern NJ
    WR 300
    johnnyboy,
    Did you turn your stock hubs down in a lathe?
    Thanks for the brake pic :thumbsup:
  13. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    The wheels/hubs are from a TE 511 that come stock with the polished hub. Husky is even nice enough to clear coat them so no chance of them festering !
  14. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
  15. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Its not for me to defend the discs but I have had no such problems
    In the past I among many others have entered a local enduro (slab common) that would eat both front and rear pads to the metal within 2 hours if it was wet due to the type of sand, shortly afterwards the chain would start skipping the rear sprocket due to all the teeth being worn away so conditions play a good part in wear and tear
    As stated the ones on my TM were near perfect and I cannot recall ever changing the pads in over a year of use that due to being the UK every ride is knee deep in water :D
    A sample of one of this years rides :lol:
    Eaglefreek and 454x like this.
  16. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    curious to see how they fare with your bike motorhead
  17. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Me too. I hope to have it for this weekend and give it a work out.
  18. ajaxauto Husqvarna
    Go one step farther and bolt up a rotor from a New TE direct to the hub Then have zip ty racing make you a extention arm for the Caliper All the bike in the Husky line up have a bigger rear brake then the Wr 250 300 My 300 how has great rear breaks that do not fade
  19. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    Dang I was wondering if that could be done. There's a new lhrb from rekluse that only works with the 4 stroke brakes.
  20. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Well, I'm still waiting from mine to get here. I've never had anything come out of the UK take this long to get here. :banghead:
