Weird handlebar problem
Discussion in '4 Stroke' started by Zestymac, May 15, 2010.
  1. Zestymac Husqvarna
    Joisey
    I have an 06' TE450 with oem 7/8 ' bars. Earlier this spring I bought a set of OEM 1 1/8" bar mounts from a member here. They were supposed to fit... I finally got my Evo bar, and swapped out the 7/8" for the 1 1/8" bar mount bottoms. All fits perfect. I try to install the 1 1/8" top cap (one piece) and discover the bolt spread on the OEM 7/8" bar mount top cap is 95MM and the 1 1/8" bar mount top cap is 85MM..
    That aint gonna work. So do I :
    Try to find an OEM 1/1/8" top clamp with a 95MM bolt spread?
    Cut the center piece out of the OEM part to get my 95MM?
    Give up on OEM and just go aftermarket?
    Anyone have an OEM 1 1/8" top clamp with a 95MM bar spread?
    Thanks for any help....Cheers, Rick :excuseme:
  2. Zestymac Husqvarna
    Joisey
    Halls hooked me up with 1 1/8" top mount with a 93MM bolt spread... No cutting! :cheers:
