Welding to frame
Discussion in '4 Stroke' started by 2wheeler, Aug 12, 2016.
  1. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    What needs to be disconnected and or removed? Disconnect both battery terminals? Unplug the computer? Rectifier? Remove tank?
    I have had subframe connectors welded to a convertible with computer before. We just disconnected the battery.
    Soon a tab made of 1/4 inch steel will be welded just above the factory kickstand tab.
  2. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    I'm not sure with modern electronics if anything really has to be disconnected. OTOH, I would do all that- and remove the ecu & tank.
    good luck.
  3. 2wheeler Husqvarna
    14 TE 310 R
    72 Suzuki TS185
    Thanks! Spoke with a Husky owner that is partners in a bike shop, repair only. I was thinking of welding a tab just above the kickstand to bolt a plate to. In my case he said to disconnect battery and unplug the ecu as I would not be that close to the tank. Anyway, now I am leaning toward tapping the frame instead. Got a rough plate done to fit a pro moto kick stand.
