What is the best fuel pump fix?
Discussion in 'EFI/carb' started by H link, Sep 13, 2011.
  1. H link Vet
    Washington
    Ok gents; give me the clean scoop here. I have a new 2010 TE 450 (325 miles) and my fuel pump took a vacation on my 1st ride. This was a demo bike, so there is no warranty. What is the best route on the repair? Thanks, H.
  2. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
  3. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    yep-
    but I'd have to say the best fix is when its just one of the 15amp minifuses that went out. then the relay..
    a buddy replaced the pump (updated stock one...$600)- without checking either the fuse or the relay...turned out to be the relay. now he's got a spare pump- don't forget to check the little things first.
  4. H link Vet
    Washington
    Checked everything, and then removed the pump asm. The pump is DOA. Is the CA Cycle works pump any good? Do I need a backup?
  5. HUSKYnXJnWI Husqvarna
    09TE450
    The CA Cycle Works Fuel Pump has been reported to be a good replacement- haven't seen any reports of those going out. I'd say that's the best replacement option (only one known to slide into the cradle without modification as well). That's what I would buy if needed.
    As far as spares go... sure if you want buy a spare. The luck with fuel pumps seems to be quite varied: some guys report early failure and some have never had an issue. I for one am running the stock one that came in my bike when I bought it in March of 2009: which has been through a lot of offroad miles/hours without issue.
  6. H link Vet
    Washington
    Thank you all---H
  7. rancher1 Husqvarna
    WA
    Hi Harlow, I would go with the CA Cycle works fuel pump option if you need one. Btw your bike should still have a warranty at those miles. mk
  8. Tech 3 Husqvarna
    Ohio
    2010 SMR510
  9. ks9mm Husqvarna
    NJ
    2015 TE 125
    2014 Beta 300RR
  10. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    To my understanding it is a direct fit but i would give them a call
  11. H link Vet
    Washington
    To let you all know, have the CA Cycleworks pump as a backup, and installed the Aprilia assembly, but changed the fuel level sensor using the Husky one. No install issues. H.
    HUSKYnXJnWI likes this.
  12. Tech 3 Husqvarna
    Ohio
    2010 SMR510
    Glad you got it worked out Great news.
  13. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
  14. H link Vet
    Washington
    Thanks for all the help Gents!
