125-200cc what is the torque of the nut that holds the water pump pinon on..
Discussion in '2 Stroke' started by eric125, Sep 3, 2012.
  1. eric125 Husqvarna
    Mass
    2002 wr 125
    2005 yamaha r6
    2002 husky wr125 the nut inside the case was loose when i removed it.. i checked the shop book it says 35 foot lbs but not sure if this is the correct part. i posted a picture. if anyone can help me out , unless its just suppose to be finger tight.. its the one i am pointing to in the pictures..
    and secondly...underneath the carburetor on the crankcase there is a tube almost like a breather.. what is that for...and should air be-able to move freely in an out of that. i blow air into the tube and it feels like it has resistance.. IMG_9229.JPG IMG_9228.JPG
  2. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    First the nut
    stick with the torque as described in the book.
    I did also put some locktite 242 (The blue one) on this one when I overhauled my engine.
    better be sure then sorry.:o
    other thing I see is that you have some wear in the fingers of your clutch basket.
    not so bad as I had but it does effect the engage and disengage behavior of your clutch.
    what you can do at this stage is to file a bit off (but you have to do that carefully that all fingers are the same amount have reduced) till you get a smooth surface on all the fingers. (Be precise if you do this) :oldman:
    The hose on your engine block under the carb is to equalize the pressure in your engine and the outside world.
    as long it is open its OK
    you do need to have a hose on it as that is the protection from water entering your engine this way when you submerge you bike in a ride.
    not having it and water enters, you will get in no time white milky troth sputtering out of this hole (not good) :naughty:
    then you're up for a complete clean out of the engine and fill it up with new oil.
    Robert-Jan
  3. eric125 Husqvarna
    Mass
    2002 wr 125
    2005 yamaha r6
    Do you know where I can order a whole new clutch set up? And or get a cheap basket.. The cheaper the better.. Running out of cash. And one of the fingers is broken off of the basket.. (previous owner). So I'm assuming that's not a good thing... Does it still make it rideable, if my fingers aren't to worn down?
  4. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    clutch baskets are in general not cheap.
    one finger of it means that the others have to share the same load so each finger will get more pressure and will wear out faster and the risk on damaging another one is bigger.
    i would not know what the safety factor would be when designing these baskets but if I would design one, one finger less should still be ride able.
    normally you don't loose the fingers with running the engine its more done with handling it wrongly (not using the proper tools to tighten things in the engine and use the basket as a leverage point) or drop it.
    if the worn fingers are to bad the plates doesn't disengage completely or smoothly so it means that the clutch is hard to regulate (which can be an annoyance in a very slow technical part of the ride) in case it is still dragging even when you pull it it adds wear on your plates accompanied with extra heat in the engine so spoiling the oil quicker and in very severe cases problem with shifting to neutral.
    Probably E bay is the best place to get it for a cheaper price than that they are worth.
    Robert-Jan
