what jets on stock 2005 te510 ?
Discussion in '4 Stroke' started by rabskyline, Nov 10, 2009.
  1. rabskyline Husqvarna
    Sunshine Coast,Queenslander !!
    2014 te250r
    Yer maw !
    gonna go up a size on main and pilot as i reckon i am still a bit lean....bike goes liek stink but a little popping on decel and it has boiled before but a while back and under hot slow conditions...however i reckon it needs upped at least one size..so, whats stock so i can order larger sizes to play with... ps i think these have the fcr 41mm ? :cheers:
  2. RLW Husqvarna
    Boise, Idaho
    I believe Stock in the FCR41MX was:
    Main: 185
    Pilot: 55
    Needle: OBDVR, at 5th clip from top
    Leak Jet: Blank
    Fuel Screw: 1.5 turns out
    Mine had above jetting (which was too rich for my area).......BUT, that doesn't mean your bike actually has that jetting. Might want to verify that first.
    The 510 can boil when working it under hot slow conditions....especially during steep 1st-2nd gear single track climbs, and the decel popping could be reduced by just turning the fuel screw out a little (some light popping is normal)
  3. rabskyline Husqvarna
    2014 te250r
    Yer maw !
    sounds normal then.... only light popping as you say and yeah , it was slow crappy hills and 90+deg/f so will turn screw out 1/2 turn and check it over.. also, whats the score with the puper adjuster screw ? turn in for more go or out ? i have added an 'o' ring over it and it makes a bigger hit from the bottom... not that it needed it lol...
  4. RLW Husqvarna
    Boise, Idaho
    When you say you added o-ring over it, which screw are you referring to?
    Sounds like you are talking about screw in the accelerator pump lever under the black cover.???
    Fuel screw is reached off bottom off carb. That's the one that is turned out about 1.5 - 2 turns out (assuming pilot jet is close)........clockwise in for less fuel - counter clockwise out for fuel more
    Once the bike is warmed up, I typically adjust it at each ride area to get best idle. An extended fuel screw really helps ease the adjustment
  5. rabskyline Husqvarna
    2014 te250r
    Yer maw !
    yeah its an o ring over the actuator pump lever..actually pulls it to squirt harder... works well ! depends on how hard you like the 510 to hit ! lol..
  6. Hbomb434 Husqvarna
    2007 TE 510
    2015 kx 250f 2007 Honda crf190 mini
    STOCK SLOW JET SIZE?
  7. Hbomb434 Husqvarna
    2007 TE 510
    what do i got here?
