what to clean oil seals with? Specifically the ones in the linkage
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by andyman, Dec 14, 2009.
  1. andyman Husqvarna
    So I find myself needing to remove the belray waterproof grease and dirt mixture that's in my seals. What chemical can I do this with?
    I've tried Dawn dish detergent hoping it would breakdown the grease and be safe for the seal... but no such luck.
    Any hints?
  2. Drew Smith Husqvarna
    Hope N.J. U.S.A.
    Solvent/Linkage
    You can soak the parts in some mineral spirits and finish up with some brake cleaner/contact cleaner and a tooth brush or simular brush. the rubber seals should stand up to the solvents but If the seals seem to be damaged you will have to replace them.:thumbsup:
  3. andyman Husqvarna
    awesome. I wouldn't have believed that if it came from anyone else. :)
    You rock. thank you sir!
    Andy
  4. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Kerosene is what I use. It's petroleum based and will not harm rubber.
    Before I'd use "brake cleaner/contact cleaner" which has the tendency of
    robbing the nature oils found in rubber, I would test them on a old seal
    first.:thumbsup: Just my two cents.
    :cheers:
  5. Slowpoke Husqvarna
    Southern Ontario
    WD40- one of the best solvents out there for grease/oil.
  6. KDXfile Husqvarna
    Alabama
    That's what I've used for many years. Works great.
  7. andyman Husqvarna
    Very interesting! So that would make cleaning out the bearings MUCH easier too! I'll keep that in mind.
  8. razornpc Husqvarna
    iowa
    i use blue paper towels
  9. Flying Trash Can Sustaining Member
    So. Cal
    TE 610
    BMW R1100R
    +1 on the WD40.
    I've come to believe that degreasing parts is the only thing this stuff is good for.
    WD-40's main ingredients, according to U.S. Material Safety Data Sheet information, are:
    * 50%: Stoddard solvent (i.e., mineral spirits -- primarily hexane, somewhat similar to kerosene)
    * 25%: Liquefied petroleum gas (presumably as a propellant; carbon dioxide is now used instead to reduce WD-40's considerable flammability)
    * 15+%: Mineral oil (light lubricating oil)
    * 10-%: Inert ingredients
    The German version of the mandatory EU safety sheet lists the following safety-relevant ingredients:
    * 60-80%: Heavy Naphtha (petroleum product), hydrogen treated
    * 1-5%: Carbon dioxide
  10. fitness2go Husqvarna
    Seattle WA
    WD 40 works good for cleaning the bike and displacing water, but I had to use a brake cleaner to get my bearings tip top. I'll try kerosene next time.
  11. ray_ray Mini-Sponsor
    The Philippines
    It works well on loosening rusty nuts \ bolts or anything stuck together that needs to be removed such as a axle bolt or swing arm bolt...This is what I think it was originally marketed for...Plus it will also remove any moisture from inside a distributor cap...The latter and all this other stuff are side effects on the ++ side :banana:
    It was dirt cheap at one time but price has gone up through time... read where the guy who invented it died a couple years back..The 40th on the end of its name stands for his 40 attempt on the formula that they finally used...
  12. tempus fugit Husqvarna
    Vancouver, Wa
    +1 on wd40 or kerosene and a toothbrush. I just go to the corner station and get some Diesel. Pretty much the same thing.
  13. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    WD-40 = Water Displacement #40
    Was the inventors 40th attempt at it. According to Paul Harvey ;)
    Good Day!
