Sorry If I'm Beating A Dead Horse, But I Like To Consolidate Information. I Found A Similar Post Elsewhere, But About Halfway Through Answering Questions The Thread Got High-Jacked And Never Fully Answered. I'm About To Pick Up A "New" '09 SM610 From A Dealer, 0 Miles On The Bike. From What I Understand Already There Are A Few Things That Should Be Done Straight Out The Door: - Remove The Extra Emissions BS (Is There A Walk-Through On This Somewhere?) - Remove 02 Sensor And Replace With Plug (Walk-Through?) - Remove The Throttle Restrictor - "Power Up Kit" (What Is This Exactly, Walk-Through?) - De-Cat The Existing Pipe Or Get An After Market One Did I Miss Anything? What Is The Break-In Period On These? Do I Need To Wait Till After The Break-In Period For Any Of The Mods Listed Above? Any Other Advice For A Newby Would Also Be Appreciated. Thanks, And Sorry If This Is All Overly Repetitive To Other Posts. -Skidd
You could leave it all on for the first 5-600 miles. It took me about 30 hours to get 600 miles on my 08 TE250 but an SM should do it in half that. By that time you'll be able to search everything and get the info consolidated. You should get a box of stuff from the dealer that has at least part of what you'll need. You can usually find all this information in the end of the Shop Manual for the bike. That you might find the manual on line or you could possibly get a digital copy from your dealer for $10 or so. If I can locate the shop manual on line I'll link it here. 2008 SM is here... some differences...maybe still helpful. http://husqvarnaoutlet.com/repair_manuals De-catting http://www.cafehusky.com/threads/2009-smr-exhaust-modification.16491/
Congratulations on your new SM610. Buy a slip-on pipe - Leo Vince X3 for around $350 - buy a $50 Lambda sensor removal kit consisting of a plug and washer for the removed Lambda sensor hole and the resistor end for where the Lambda sensor wire used to connect under the gas tank. Then you will have to adjust your idle down a few hundred rpm's and you are all set. You can have your bike ripping for around $400. Removing the smog shit is mainly for looks and less weight and is also very easy.
