125-200cc what's it called?
Discussion in '2 Stroke' started by gazmcfaza, Jun 17, 2014.
  1. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    for my wre 125 2005, I think I need a new front brake lever and also the rubber piece that the lever swings into when you pull it inwards, the rubber bit that compresses, what is it called?? I can find levers aplenty on ebay but don't find anything when searching for front brake rubber!!
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    The dirt catcher type thing?
    The bit that seals out the crud from the action.
    or the seal that stops the dirt going into the brake master cylinder? Thats a master cylinder seal
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Unfortunately, it doesn't look like that part is offered anywhere. The rubber piece that you seek is part of the piston assembly, which is offered up as one complete unit by most Japanese manufacturers, but doesn't seem to appear on a Husqvarna fiche. Maybe contact the supplier of the front brake cylinder unit.
  4. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Motosportz and gazmcfaza like this.
  5. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    thanks for the link, I'm after the bit where you can see my finger, it seems to want to jump out of the brake lever rather than slotting in 180620141922.jpg 180620141923.jpg
  6. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    that's a boot that comes in a kit
  7. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Thats the rubber boot in the ebay pic dude.
  8. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    It sounds like your problem is with the plunger, not the rubber piece. The rubber piece is just a boot to keep dirt out, the lever pushes on the end of a metal plunger that pushes the piston into the cylinder.
    It could be that your plunger/boot is worn, and you need a kit like the one shown in the pic above. However, if the "socket" that it sits in on the lever is worn, that might make it pop out too.
    I'd probably just replace both and be done with it...
    ray_ray likes this.
  9. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    thanks for the advice and links, I was just coming home and suddenly my lever felt ''notchy'' then I realised I had no brake at all! Pulled over and yes the little plunger had popped out of place and was resting above the gap in the brake lever that it was supposed to pop into, so pulling the lever did nothing at all. I put it back together by taking the lever off and on again but can't be having that at 60mph! The rubber boot, plunger and spring appear worn out I think so I will order the kit :D
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Make sure its the right kit not sure how generic they are.
  11. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
  12. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Should do aslong as the boots your only problem and you dont need the master cylinder piston assembly too, was the lever covered in brake fluid? If so get entire rebuild kit .
  13. 2premo Husqvarna
    Northern NV
    realistically if your master needs more than a plunger and boot buy a NEW master
    what is your life worth
  14. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    ? Yeh you could do that or you could not waste asmuch throwing away servicable parts, if my brakes arnt working i buy new pads not the entire caliper, why would you buy a new master unless its been smashed beyond repair.
    End of the day gazmcfaza its your cash if you feel happy doing the work and acheiving job satisfaction buy a kit, if youve got no time an lota money buy a new bike sorry a new brake and bolt it on.
    The choice is yours!
  15. gazmcfaza Husqvarna
    uk
    husky wre 125
    , yamaha xt 125
    sorted, went to a mechanic I knew at school, he put a new spring on, welded a tiny bit onto the plunger then ground it down in even tinier amounts until it fitted snugly, back together now and works perfectly :D free of charge too!
  16. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
