whats the best way to get white tank White again?
Discussion in 'Vintage/Left Kickers' started by NZHusky, Oct 16, 2010.
  1. NZHusky Husqvarna
    Napier,New Zealand
    apologies if this has already been asked........how do i get my 85 WR400 tank outside cleaned. It has the typical "off white" look from the 2t oil bleeding through over the years.
    Thanks in advance..Phil :excuseme:
  2. White Husky Husqvarna
    UK
  3. NZHusky Husqvarna
    Napier,New Zealand
    cheers for that and sorry....i should have searched first
  4. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    I wonder if the discolouration IS the fuel coming through ?
    If so then why are ALL my plastics the same colour?
    Am starting to think that they are not UV protected.
    Mike
  5. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    I'd disagree about the discoloration coming 100% from the inside, granted the fuel is causing the problem, but i think it's because the fuel softens the plastic slightly & allows dirt to get ground deeply in to the plastics pores.
    I've sanded down 3 white tanks & i've gotten them about 90% white,by just removing the top dirty pores, so to speak. I'd agree to a small degree that the sun UV rays has something to do with it too.
    I know the the graphic peeling is caused by the fuel, but i've repainted a 4th white tank & after a year other some very minor bubbling the tank still white.
    In my opinion if you ride your bike, sand it down to get it close to it's original white & get some vented graphic & be done with it.
    I can post pics of a sample white tank i've done before & after pic of.
    Husky John
  6. Back when I had a white tank I used cleaner wax, it pulls the dirt out really good. I dont know how effective it would be on a clear tank but on white it works great.
  7. ruwfo Administrator
    NJ
    Here's a couple of pics
    Here's a KTM 495 tank i sanded down recently, the more i sanded the more dirty white color i got rid of. You'll never get it white white , like new,but it's looks 1000% better. It was a very cloudy day when i took these pics,but it still looks pretty good.Last pic is almost complete,still need to get the graphics.
    Husky John
  8. NZHusky Husqvarna
    Napier,New Zealand
    Thanks fellas, thats what i love about this site...so many good,helpful ideas !
    Im into it now and have found in Australia some decals with breather holes
    Cheers
  9. Fritzcoinc Husqvarna
    Cypress, Texas
    I have removed a lot of the brown, not all, with bleach. The fenders and air box were just dingy and the bleach whitened right up.
    And I found bathroom cleaner does a pretty good job removing brake dust.
  10. LEADVILLEHUSKY Husqvarna
    COLORADO
    I just did my 84 xc 250, started with 1200 grit da paper up to 3000, than white wall cleaner and a grey scotch bright. Looks ok, just cant get some of the bleed thru out but it worked good
  11. mike328 Husqvarna
    colorado
    I have used arm & hammer baking soda..to clean outdoor plastic white lawn furniture.
    make a paste and use a rag to apply...rub & rinse.
    remember this stuff is like salt & will kill grass/vegetation so do this on concete etc..but safe of your hands
  12. Daniel508s Husqvarna
    Vacaville, CA
    2009 TC510
    2009 Suzuki RMz450, 2013 KTM250sx
    Tilex bathroom cleaner and bleach? Thanks for the tip :thumbsup:. Simple Green works wonders to.
