I searched but didn't find anything Does anybody have the dimensions for the wheel bearings (front and rear) for a 2007 TE510 ? Mine are toast and I'd prefer to buy replacements from a local bearing shop if possible instead of using the All Balls kit. TIA Cheers
25 x 42 x 9 mm. https://www.halls-cycles.com/Catalog/PDF/Husqvarna .PDFs/2006/2006-DOHC-Husky-parts.pdf edit: oops, sorry, didn't read well enough to see you were asking for front and rear. Got front only stuck in my head for some reason.
For rear wheel you will need 3 bearings per below.. Qty 1 X Husqvarna Part #: 8B00 26846 / 63005-2RS / ø25xØ47x16 mm Qty 2 X Husqvarna Part #: 8A00 26846 / 6005-2RS / ø25xØ47x12 mm For front wheel you will need 2 bearings per below.. :ride: Qty 2 X Husqvarna Part #: 8000 84938 / 6905-2RS / ø25xØ42x9mm NOTE: Older front wheels used this bearing.. Qty 2 X Husqvarna Part #: 8000 39651 / 6004-2RS / ø20xØ42x12mm
Thats awesome info. Any ideas if its true for 05 and 08 TE450 ? Any ideas where to buy online, or, in Australia?
Pete, The wheel bearings should be the same for both your 2005 and 2008. You can cross reference here to be sure though. https://www.halls-cycles.com/Catalog/Halls-Cycles-Husqvarna.aspx Wheel bearings come in standard sizes. They are not a moto or brand specific part, so any reputable auto or industrial supply company should be able to get them. Just make sure to get sealed bearings and not a cheapo brand either.
Pete, any decent bearing shop will have what you need they only require ID, OD and width. As said get quality sealed bearings from Europe or Japan (SKF). There is a great post from Seahorse here about repacking new bearings before inserting them (excellent photos etc) as they come with inadequate grease from the factory. You will find it about 12 lines down in the technical reference section.
I already ordered them before i read this...not sure of the brand, but husky australia quote was $300 per bike, i paid $32.50 delivered. Will post the brand once they arrive.
Hey you wouldn't happen to know where I can find the wheel bearing and sprocket carrier bearing sizes for the 701E? I've searched a while but no luck yet...
