250-500cc Wheel compatibility WR250 1996 vs 2010
Discussion in '2 Stroke' started by Hurky, Oct 14, 2015.
  1. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    Hi, I have a 2010 WR300 and I've seen a good offer for some 1996 wheels, I know that they're visually different, the HUB is different and the rear disk brake is having more than the 4 screws my 2010 has, but, can I mount them on my bike ? I think maybe the rear would fit OK with the old brake disk but I don't know it the front will also.
    Anyone have some info ?
    Regards.
  2. rancher1 Husqvarna
    WA
    The first problem you will have is the axle sizes are smaller on the old wheels.
  3. R_Little Husqvarna
    NJ
    They changed in 2002. I think the 1999 rear wheels fit with just a axle spacer change.
    i think the 1996 are totally different.
  4. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    Correct R_Little, hubs are different as well as disc bolt pattern and the axle size....l think the width is still the same though?
  5. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    the bearings from a 2004 to yours and probably beyond fit the 96 wheel hub, but the problem is you need custom spacers
    i am in the middle of this updated my forks and the wheel won't work so adapting mine
  6. rancher1 Husqvarna
    WA
    This might be true on the front wheel but the rear will not work that way at all.
  7. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    Ok thank you all !!
