Trying to figure out which wheels are compatible with my '07 TE 610. I'm open to either TE or SM wheels, and ideally I would like to just bolt on an identical rotor to what I already have to make the swap easy. I'm fine with the TE brakes. What models/years of TE wheels would fit? What models/years of SM wheels would fit? Thanks.
I have noticed that in some cases the nipple spacing on the rims for the spokes vary so it can be tricky. I wanted to put my rims on my 2003 off of my 2000 but the rims will not fit. The spoke spacing is different. So if I wanted to use new rims I would just order a new blank rim and have it drilled to match my hubs. New excel rims front and rear drilled the way you need it with spokes will cost around $600-$800. That's not including hubs since you would be using your stock ones. I hope this helps.
