Wheel Interchangeability
Discussion in 'General (Main)' started by huskyte610e, Feb 23, 2009.
  1. huskyte610e Husqvarna
    Anyone know what the compatability of older model wheels is for late models huskies?
    I'm pretty sure that the front axle diameter changed circa 2000, and also a slight change in the width, but not sure about the rear.
    I presume that the situation is that:
    - all rears are the same post say 1991
    - front were the same until (:confused:) and are common on all models since then
    Can anyone provide some more answers to this?
  2. BlueHusky144 Husqvarna
    Staunton, IL
    Hub Changes
    I have found that anything after 2001 is compatible with newer models. 2000 is a time period that is questionable as far as compatibilty goes. Just verify part numbers with your dealer, to make sure it fits.
