When does your radiator fan switch on ?
Discussion in 'TR650' started by johnb, Apr 29, 2013.
  1. johnb Husqvarna
    Northern Rivers NSW Australia
    tr650
    yz450f
    I think there is a problem with my fan its only been on about 4 times in 4000K
    all four times were in thick grass/slow going and there was coolent coming out before the fan
    came on!
    I am thinking of putting manual switch on. Any idears?
  2. Next Strada Demolitionist
    Brevard, NC
    Mine comes on in the mountains on long windy gravel roads, usually when the going gets slow. So far, it always cools the bike down and then shuts off.
  3. blaine.hale Husqvarna
    2013 Terra TR650
    1973 BMW r75, 1974 BMW R90, Bultaco
    Mine comes on in Atlanta traffic (stop and go) very frequently. When I'm in constant motion, even below 20mph on the trail...it never cuts on. All about keeping wind moving over that radiator :)
    Moff69 likes this.
  4. Next Strada Demolitionist
    Brevard, NC
    I cracked radiator open for kicks tonight while wiring in some grip heaters. Turned out I was low in the radiator. Burped and filled. Wasn't overheating, but it is now as it should be. Better to check it than to assume it is correctly filled.
    Moff69 and Louisbiker like this.
  5. Kenneth Webb Livin' It Up!
    Tucson AZ
    TE630 TR650 Terra TE310R
    My fan has only started when I was in heavy stop and go traffic for an extended period. Then, it was running about 90 percent of the time. As soon as traffic started moving, no more fan. 'Guess it's doing it's job.
  6. organ donor Husqvarna
    Berlin
    It´s like trying to find out if the fridge light goes out when the door´s shut.
    snail_72, Moff69 and HARDER1 like this.
  7. blaine.hale Husqvarna
    2013 Terra TR650
  8. kjackbrown Keep on keepin on.
    Fresno, Ca.
    KLR650
    lol...yes and yes
  9. blaine.hale Husqvarna
    2013 Terra TR650
    whoops. Freudian slip. 4:42
  10. huskyrob450 Husqvarna
    Huntington Beach ca
    2012 txc511, 1981 430xc
    08 450 exc, 74 DT250,360, 75 h2 kawa
    I have a 2012 511 txc fan has never turned on, the rad cap was stuck some how so it would not boil over. The first time I pulled the cap the rubber washer that seals the cap was stuck to the radiator. The coolant level was fine , I put a new 1.8 bar cap (stock pressure) back on and the bike boiled over every time I went out. I switched to a 2 bar 30 psi instead of 20 psi. The bike has not boiled over but does get too hot. Just rewired the fan to a manual switch. Just a side note, thought I could cut the wires to the thermal switch on the radiator and run them to a manual switch. NOT !! the bike wont run with that radiator sensor out of the loop:naughty:
  11. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Not sure with a 511 but the Terra does not have a separate switch. It has a coolant temp sensor, using the ECU to switch on the fan. Sounds like you cut into that. Ouch!
    By using a higher pressure cap, you have raised the boiling point of the coolant. Does the 511 have a temp gauge/indicator?
  12. huskyrob450 Husqvarna
    Huntington Beach ca
    The TXC does not have temp indicator. Yes , the ecu should turn on the fan but doesn't . So I installed the switch.
  13. FER QUILES Husqvarna
    SPAIN
    TR650
    KLE500, HONDA NX650
    Anyway, my fan is working well, it is not ready to low heating quickly.. Terra is over heating, much more than my last NX 650 air cooling.
  14. Ignaciob Husqvarna
    Tri-Cities, WA
    TR650 Strada --> Terra (aka Noxeema)
    05 Yamaha FJR (x2), 75 Honda CB400F
    How do you know? Is it boiling over? I don't think anybody has correlated the temperature display to actual temperatures, but unless you know it's getting over the 05-110 C (220 to 230 F) range...I think most cooling systems are designed to run up to this temperature. I've run across many people over the years that think because it's over halfway on the indicator....that's automatically bad or something.
    Personally, I've noticed the fan will come on in traffic on nice summer day and when I'm going relatively slowly up mountain roads. It's working as expected.
  15. Trapperj Husqvarna
    Knoxville TN
    Tr 650 Strada
    R1200 GS RALLY..KLR 650..Zrx 1200
    The "manual" says to check the oil level to allow the bike to idle for 3 minutes after the fan kicks on...then turn off and check the oil level. I remember trying to get my fan to come on in winter and took forever. I thought it was broken..but it did finally turn on.
  16. FER QUILES Husqvarna
    SPAIN
    TR650
    KLE500, HONDA NX650
    Personally, I've noticed the fan will come on in traffic on nice summer day and when I'm going relatively slowly up mountain roads. It's working as expected.[/quote]
    The heat from the engine when you stop is much strong than NX650 air cooling or kawa KLE500 water cooling system. It has something to do with the
    main pipe from the cilinder, to close to left leg. I have said the fan works perfectly, but Terra is dificult to cool in a hot day below 30km/h, which is very
    hot to ride in the city.. however bike runs great when it is frozen..
  17. broadwayron Husqvarna
    Brooklyn
    '13 TR650 Strada
    '10 520RR
    Regarding the fan... can it stay on for a bit when the bike isn't running, even if the key is switched on? Mine doesn't seem to, but this is a tough thing to "test" (plus, I don't really want to test it).
    My other bike's fan will stay on for a couple minutes after the bike is shut off, which I like (and, it makes sense).
  18. drzcharlie Husqvarna
    Bike off, power off, fan off.
  19. broadwayron Husqvarna
    Brooklyn
    '13 TR650 Strada
    '10 520RR
    You mean, it's dependent on the electrical system being off ("key off"), or the engine being off (key on, engine not running)?
  20. drzcharlie Husqvarna
    Sorry, key on, engine off (using the kill switch) the fan will run. Key off, engine off, the fan won't run.
