125-200cc Where can I buy a crank?
Discussion in '2 Stroke' started by dan92, May 25, 2016.
  1. dan92 Husqvarna
    WR125
    yamaha WR426
    The stubs of my crank have worn so much that the mains slides on and off by hand (I've never seen this before....? What would cause it?)
    Anyway, obviously I need a new crank but after and hour of scouring the web (I even went past the first page on Google, now that is dedication) I cant find one.
    Anyone point me in the right direction please? Or if you have a good one you want to sell, even better!
  2. dan92 Husqvarna
    WR125
    yamaha WR426
    Should probably have mentioned, it's for a 2001 wr125
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
  4. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    You can have it ground, re chromed and the resized.
  5. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    If offered a later model crank be forewarned they are not the same ! Webs are smaller in diameter - main bearing area is machined smaller ect ect although the rod is the same.
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i had the same problem, only the cases on an old 79 were worn..the mains just slid out of the cases..
