WHERE TO BUY- TWIN ARROW MUFFLERS w/CPU from Special Parts Catalog
Discussion in '610/630' started by Huskymicky818, Jul 9, 2013.
  1. organ donor Husqvarna
    Berlin
    The ones I got are stamped to make them street legal over here. If you can´t get them anywhere else, Zupin can usually help.
  2. Huskymicky818 Husqvarna
    Hidden Hills, CA
    2011 SM630
    '04CRF450x2,01&03YZ250,87CR500x2
    what kind of iridium plugs did you use and what part number?
  3. HuskyBrutha Husqvarna
    SM630
    690 R, 500 EXC, XR250
    NGK - CR8EIX
  4. B1MIKE Husqvarna
    2009 Smr 450
    2008 YZ125
    I just got the pipes without the ecu from Halls cycles, it might have been their last cause I had to get the pipes without the ecu. Now I'm searching for the ecu!
  5. Russ Husqvarna
    Sydney
    TE250i & 701 Enduro, 501 & 630 sold
    Interestingly, when the Aussie bike magazine Trailzone had a TE630 as a project bike for a few months in late 2011 they fitted the Arrow pipes, but chose to leave the standard ECU in rather than replace it with the Arrow one. Seemed odd to me, but their cited reason was better mid range performance compared with the Arrows at the higher end.
    I don't know about this, as mine has both the Arrow pipes and ECU, plus JD tuner, and it has a heap of crisp grunt from low/mid revs. They said fitting the pipes transformed the bike's performance.
  6. Huskymicky818 Husqvarna
    Hidden Hills, CA
    2011 SM630
    oh i actually found them at Motoxotica minus the main heat shield, i got it all for a really smokin deal, so i would hit up Motoxotica and check if they could get you one! WHAT A NIGHT AND DAY DIFFERENCE, ONCE YOU REST YOUR IDLE YOUR IN THE MONEY
