Where to get an OEM spark arrestor for the stock pipe?
Discussion in '4 Stroke' started by thek, Nov 30, 2011.
  1. thek Husqvarna
    Does any one know where I can get an oem spark arrestor for the stock pipe on my txc 510?
    I've had a look online but hav'nt been able to locate one.
    I got the bike the other day and it is too loud for my usual riding area.
    And are they easy to install (ie do you just pop them in?)
    thanks
  2. waserman Husqvarna
    Delaware,USA
    09 TE510
    BMW KTM Honda
    What year is the bike ? I believe that the stock muffler is the same part as the TE/TC/TXC and therefore you should be able to get 1 from your dealer. If that's the case it will just insert into the end of the pipe and be held in with a snap ring, I also like to use some high temperature silicon sealer to keep it from rattleing around.
  3. MontyCarlo Husqvarna
    Part number is 8000B1307 for most years. Any dealer should be able to order you one. They do in fact just "pop in" but they are held in by a circlip so you will need some circlip pliers.
  4. thek Husqvarna
    sweet thanks for that guys my bike is an 09 so i should be right.
  5. HUSKYnXJnWI Husqvarna
    Central Wisconsin, USA
    09TE450
    YEP, just to confirm: mine from a 09TE450 fits the 08TE250/08TE510/10TE510/10SM510 cause I checked. TXC should fit alike.
  6. thek Husqvarna
    Hi this is the style of my exhaust do you know the part number I would need?
    (example only not my bike)
    thanks
  7. TheRealBuzz Husqvarna
    2009 te 450
    I'm looking for this same part. No longer available direct from Husky. No stock at Quad Experts. Gonna call Langs next. Anywhere else in Ontario I should try? New or used. Thanks.
  8. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    I am not digging into this but you can, your exhaust should be the OEM Arrow special parts exhaust. In the US we have Motovation as the Arrow distributor you could contact them. I do know that when you order an off road pipe kit it comes with the dB killer cap/plug which is the same plug minus a piece of screen on it. Maybe you could get one of those dB killer plugs separate ans add some screen material if you are concerned
  9. robertaccio Husqvarna
    San Diego, Ca
  10. TheRealBuzz Husqvarna
    2009 te 450
    Thank for the info robertaccio
  11. R_Little Husqvarna
    NJ
    Yes, the stock S/A fits the arrow aftermarket pipes.
