Where to mount a pair of auxiliary light on TE630
Discussion in '610/630' started by alpha26, Jun 23, 2013.
  1. alpha26 Husqvarna
    Australia
    2011 TE630
    BMW F800GS, Ducati Multistrada
    Hi guys,
    I have just purchased a pair of 30W auxiliary lights for my TE630. Does anyone have a good idea as to where to mount them? Aux light.jpg
  2. EricV Husqvarna
  3. DYNOBOB Husqvarna
    I had mine at the lower triple clamps but moved them to the Barkbusters because of the Safari tank.
    Coffee likes this.
  4. RDTCU Husqvarna
    '11 630SMS
  5. alpha26 Husqvarna
    Australia
    2011 TE630
    Thanks guys,
    I will have to mount the lights onto the Barkbusters as I also have a Safari tank. Do you connect the lights along with the high beam wiring, if so where would be the best place to connect? This would save additional wiring , relay, and on/off switch.
    DYNONBOB, compliment to your clean looking bike! Do you have any problem with light reflecting off your screen? I will have the same problem with my Slipstream screen.
    My headlight lense is looking rather sad too. I am not sure if it is caused by the 55Watts HID light that I installed.
  6. DYNOBOB Husqvarna
    I took the windshield off for now because the brackets also hit the tank. I had a little reflection from the headlight but rarely ride this bike after dark.
  7. alpha26 Husqvarna
    Australia
    2011 TE630
    Do you connect the aux lights with the high beam or separate wiring direct from battery?
  8. RDTCU Husqvarna
    '11 630SMS
    I pulled power for mine off of the battery with an in-line fuse block and a relay pulling the signal from the high beam relay, so they're on their own fuse, but they come on with the high beam.
  9. alpha26 Husqvarna
    Australia
    2011 TE630
    Thanks. Sounds like a good plan, I will do the same.
  10. WickedWill Husqvarna
    QLD,AU
    some little red ones
    Just got back from a big ride that i clocked a lot of night hours.Have them mounted on the barkbusters. Worked excellently.I have power to a small fuse block mounted up front.This is hooked to a relay wired off the high beam feed at the headlight also have a switch to turn them off.
  11. alpha26 Husqvarna
    Australia
    2011 TE630
    WickedWill, nice fuse block. Where did you get it from? Is there an easy way to tap into the high beam relay? I think it is the Green/Black wire is the high beam relay wire?
    I am heading off for a big ride next month. Melbourne to Mt Dare, ride across the Simpson Desert to Birdsville, then onto Cape York, down through the coast to Brisbane & Fraser Island before heading straight home.
  12. Sizzler Husqvarna
    Blue Mountains
    CBR600, SZR660, TLM260. DRZ250
    That is an impressive ride.
    I thought that my planned Mornington Peninsular to Cape York (in a direct route as possible) sounded ambitious.
  13. WickedWill Husqvarna
    QLD,AU
    The fuse block came from supercheap i think.
    http://www.supercheapauto.com.au/online-store/products/SCA-Automotive-Fuse-Box-4-Way-Blade.aspx?pid=120458&menuFrom=40105#Cross
    I tapped into the wire at the headlight socket for high beam.The relay i used is just for the aux lights,it came with the lights.Battery goes to fuse block,fuse block power to the relay , high beam wire triggers the relay.I have a switch inline from the relay to the lights so i can just run high beam if necessary.
    Your trip sounds awesome.I can't wait to get back out to the simpson on the 630.
  14. alpha26 Husqvarna
    Australia
    2011 TE630
    Thanks. I will head out to Supercheap Auto tomorrow and pick one up. Nice wiring job too.
    This will tidy up my wiring. I will hook up the heated grip, GPS and cigarette lighter socket to the fuse block.
