250-500cc Where'd my gear oil go?
Discussion in '2 Stroke' started by Speedlabdan, Dec 9, 2020.
  1. Speedlabdan Real bikes are right side drive
    South Jersey
    2010 Husqvarna wr300
    1989 kdx 200
    Ok, maybe a stupid question but.... In my 2010 wr300, I've noticed after extended rides there is no oil left in the gear case. No noticeable weeping, drops or excessive smoke. I know in a 2t the gear case is separate but is there a way the oil could be burning off in the top end somehow? I just competed a98 mile run and upon completingtthere's only maybe 4 tablespoons in the drain pan!
    I'm changing out the clutch bc it started slipping towards the end and now it's pretty evident why. What do you guys think?
  2. NvRider55 Husqvarna
    N. Nv.
    2001 wr360
    KTM 525ex, 250xc 2T, 200sx,300mxc
    Most likely the crank seal on the trans side is bad, you can usualy smell the gear oil burning and white smoke.
    Speedlabdan likes this.
  3. Speedlabdan Real bikes are right side drive
    South Jersey
    1989 kdx 200
    I should probably do both sides so it doesn't lean out so I hear, come to think of it, it has smelled funny
    NvRider55 likes this.
  4. Sonnie Mee Husqvarna
    England
    Team Motorex Husqvarna CR125
    Yeah sounds like the crank oil seal leaking to me your burning the oil off
