Where's the rimlock?
Discussion in '610/630' started by Philthy, Apr 22, 2013.
  1. Philthy Husqvarna
    Mackay, Australia
    Yammy WR250f
    Just wondering what most guys are doing with tyre pressures and tyres for offroading the TE 630. Coming off an enduro bike I assumed the tyres on the 630 would be rimlocked,doh! I'm guessing the 20-22 psi tyre pressures are to ensure the tyre doesn't slip on the rim?.
    So is anyone adding rimlocks and running lower pressures for softer terrain?
    Thanx Phil
  2. mekanik Husqvarna
    Kootenays, Canada
    light weight motion pro rim locks, still looking for perfect pressure
  3. EricV Husqvarna
  4. Philthy Husqvarna
    Mackay, Australia
    Yammy WR250f
    Thanks, yep I thought it was getting a little twitchy at about 110, maybe needs some adjusting in the fork clamps.
  5. R_Little Husqvarna
    NJ
    Street wheels are hard to balance with rimlocks at highway speeds.
    Maybe use 2 rimlocks to even out the balance.
    Also, rimlocks put a "bump" in the tire as it rolls on the road.
    You can also think about a "TU-Bliss" system.
    Philthy likes this.
  6. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    Motion pro now offers balance weights that are narrower than the ones for car wheels. They will fit on the rim lip without sticking out.
    I think I broke my lightweight motion-pro rimlock on the rear and put a standard in there last time I changed tires. The thing was vibrating pretty good anything over 60. Just took the wheel off today and re-balanced, took 3oz of weight to balance it! It was WAY off. I'm pretty sure I still have some internal weights but not nearly enough.
    Yes, install a rimlock. Even if you don't run low enough pressure to slip the tire (it probly will anyway) if the pressure runs low or you get a slow leak and don't notice it, the tire will spin and pull out the valve stem. Never regretted installing rimlocks on mine. Run 17-18lbs in the rear for any really tough going. Smooths out the ride too.
    The front will slip from braking as well, anything under about 22-23lbs. I like to run 20, even 18-19, so the lock is a necessity.
