Which Motoz tires and what size?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Mike-AK, Jan 31, 2013.
  1. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    I think I need a set of Motoz tires to replace the Karoo's on my 2012 TE310. I have no plans of riding this bike on the road, and I have done the power-up and swapped out the TE ECU and injector for the TXC ECU and 12-hole injector. I am in South-Central Alaska. Terrain varies from silty sand to rocks and roots, muddy, rocks, roots, hardback, and loose and dusty. Pretty much everything. Any recommendations on which Motoz tire to go with, and what size would be best for the rear would be appreciated. The 140 Karoo is way too big, but I don't know if I need a 120 or a 110 for the new Motoz tires I want. Thanks in advance for your help.
  2. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    I used 110 size for both my 250 and 310. I have used the X-circuit and IT in rocky, rooty, wet, dry and DS riding. I perfer the X-circuit because they seem to bounce less, and better overall consistant traction. I also feel the X-circuits have stiffer sidewalls which comes in handy with low air pressure. With the IT's there was a range of PSI needed to keep the front tire in traction while becoming too aggressive and keeping the front stable. The range was 10-12 PSI which resulted in several pinch flats. I ran 13-14 PSI with X-circuit and had no flats or bounce. Now I run TuBliss and keep the IT's at 12 otherwise they grip too much in ruts and wanting to climb out. I have a set of IT's in my garage and when there gone I will be back on the X-circuit again.
  3. Mike-AK Husqvarna
    Alaska
    2012 TE 310
    Have not had much luck finding Motoz tires in the right size. All I see is 100 and 130. Guess I will go with Maxxis SI's.
