Which pipe is which????
Discussion in '2 Stroke' started by troy deck, Feb 6, 2013.
  1. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    I am in need of a pipe for my nephew's 12cr144. I have found DEP's, DOMA, HGS, Scalivini, and a new one this morning. Big one, a hand welded cone pipe from Italy. Has anyone tried any of these???
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    well so far i have found 7 different mfg's pro circuit, fmf,dep,doma hgs, scalivini,big one,...kelly time for some testing big one looks real good & has spark arrestor
  3. Coffee CH Owner
    I can see you are having trouble using the site, understandable, a lot to figure out - for that I apologize.
    I merged the 2 threads you started in Dealer Kudos, then moved the thread into 2st where you will probably get a much better response.
    Welcome! :cheers:
  4. john01 Husqvarna
    Powhatan VA
    I had the FMF Fatty on my CR144 and it worked great. Better power everywhere over stock. I hear the Scalivini pipe (hand made pipe from Italy) is a real screamer; looks cool too. I'm sure a few others that have used other pipes will chime in to help.
  5. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    if your good with a welder you can even use kawasaki 125 pipes i put a noleen racing unit on my 144, worked better than the pc platinum.
  6. ajaxauto Husqvarna
    I really like the FMF PLUS FMF has taken the time and effor to work with me and walt on the 165 project for me that goes a long way and I would want to support a company who loves the 125 like the rest of us
    CALL your dealer or FMF direct if you call FMF work with Mike at ext 241
    310-631-4363
  7. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    FMF seem to be the best value and add to bottom to mid more than most but if you have the $ try the Scalvini
    Q. Is the 2012 CR 144 pipe designed for the 144 and diffferent to 125 pipe?
  8. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    somebody makes a 144 specific pipe??
  9. john01 Husqvarna
    Powhatan VA
    Not that I have ever heard of. The FMF 125 Fatty does work very well with it though.
  10. CelticDude Historically Fast!
    x
    I can vouch for the Scalvini. Significant power increase from mid to top end!
