250-500cc Which pre-mix and what ratio?
Discussion in '2 Stroke' started by JDJ, Aug 10, 2012.
  1. JDJ Husqvarna
    Idaho
    2009 WR 300
    prev07 YZ450F , 07 CRF250X , 03XR250
    I know there are likely as many opinions to this one as there are types of oil but I am new to Husky and even newer to 2 strokes. Never had to mix gax except for my weed eater. So I have a 2009 WR300 and I am just looking for suggestions on which pre-mix to use and what ratio. I have heard good things about the Klotz R50 and the guy i bought the bike from suggested 50:1. Any thoughts
  2. marcmo0 Husqvarna
    Auburn, WA
    09 WR300
    Yamaha YZ250
    50:1 is recommended by Husky. So good to go there. As far as brands go...just pick one that is readily avail to you. Almost everyone on here uses different stuff. I use bel ray H1R. Good stuff and easy for me to get.
  3. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    any fully synthetic i always go 40 : 1.
  4. knucklesdad Husqvarna
    Sunshine Coast Australia
    CR 65,CR144,TE510,Tc85,Tc125,Fc450
    ,HD sporty1200, ttr 50, pw50, Ktm 50
    Motul 800 40:1:)
  5. Gotlabs Husqvarna
    Branchville, SC
    12 CR144 X 2!
    spectro at 40:1
  6. giantjoe Husqvarna
    Canadia
    2010 WR300
    Motul stinks like fish. Don't use it. I use blue marble. 50:1
  7. Glenn haynes Husqvarna
    western pa
    2012 wr300
    13 yz250f 08yz85 11ktm 65 09 ktm65
    Motul 60:1 . My topends dont lie
  8. Geno Husqvarna
    anywhere but here
    not anymore
    12 tm 250en,300mx 07 250fen,13 450en
    good reason to pass the guy. klotz kl-100 has slightly lower flash point than r-50 = less spooge
  9. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    I use Amsoil Interceptor 50:1,just took my head off after 4yrs to look at things and everything looked brand new,no carbon buildup at all.
  10. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Motorex Crosspower at 60 to 1. Smells good, burns with little smoke, power valves stay clean, engine parts last a long time.
  11. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I use Klotz KL-100 at 50:1. R50 at 50:1 would be good, but as Geno said it spooges more.
  12. lankydoug Husqvarna
    MO
    WR
    TM 300en
    Any full synthetic is good. If you find one with a flash point that agrees with your jetting and riding style you will have minimum spooge and silencer packing will last longer. I use Ammsoil Dominator but if you are going to put around Ammsoil Interceptor would probably be better. I mix at 50:1. There are lots of good mix oils out there, using good fuel is extremely important and often overlooked. At the very least avoid any ethanol blended fuel.
    typeone and huskybear like this.
  13. huskybear Husqvarna
    B.C. Canada
    Amsoil interceptor at 40:1 and non-ethanol 94 octane pump gas works for me!
    lankydoug likes this.
  14. mnnthbx Husqvarna
    knoxville
    2013 CR 144
    Thriumph Thruxton, Honda Ruckus
    I've run Motul 800 forever, and the internals of my engines are in freakishly good condition. Talk your friends into running Klotz though. Smells the best when running....
  15. Steve-oh Husqvarna
    Lethbridge, Alberta
    2010 WR 300
    04RM250, 05XR100,07PW80,41 Harley
    Amsoil Dominator, 50:1, 95 octane, its a bloody rocket.
  16. kjclark7 Husqvarna
    2008 TE510
    anyone ever use this stuff?
    2 cycle oil
    Opti-2 is a specialized two-cycle, single mix ratio lubricant engineered for use in all two-cycle engines, regardless of brand, model, or mix ratio. Opti-2 is rated ISO-EG-D++, the highest rating available in the stringent International Standards Organization global performance ratings system. Opti-2 meets and exceeds all equipment manufacturers rating requirements. Opti-2 is formulated utilizing patented Eutectic additive technology that provides exclusive performance results:
    • One gas can covers all two-cycle engines
    • Highest rated 2-cycle oil in industry
    • A single mix for all two-cycle engines
    • Increased performance and longer engine life
    • Smoke-free operation
    • Gasohol compatible
    • Contains "Opti-Mizer" 24 month fuel stabilizer.
    Opti-2 delivers all these features while being the most environmentally friendly two-cycle mix oil available. Opti-2's smoke reduction, and gasohol compatibility contribute to cleaner air, while up to 60% less oil is required, which helps conserve a precious non-renewable resource.
  17. huskybear Husqvarna
    B.C. Canada
    I have used it before and it seemed to be pretty good but it was hard to find. I use amsoil interceptor at 40:1- good stuff!
  18. kjclark7 Husqvarna
    2008 TE510
    its easy to find by me. its so easy too. just have to have 1 mix can for all different types of mixes. this stuff is all i have used for about 10 years and i was curious as to why no one else suggested it.
  19. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    Is it really smoke free?
  20. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Yamalube 2R at 50:1
