Which sealant do you use?
Discussion in 'Vintage/Left Kickers' started by Hwy, Feb 11, 2010.
  1. Hwy Mini-Sponsor
    SF Bay Area
    '86 510TX / '90 250WXE / '87 510TE
    '04 KTM 525MXC / '91 KTM 300DXC
    Fifth times a charm...I hope.
    Have a hellva time sealing the cylinder cover without a gasket. It seeps oil when hot at different points. Never at the same spot after resealing the cover. Cover is not warped.
    I've tried these four products:
    • Permatex Ultra Copper
    • Napa/Permatex Form-a-gasket Aviation
    • Yamabond
    • Permatex Form-a-gasket #1
    What product has worked for you guys?
  2. fran...k. Husqvarna
    eastern ct
    What is a cylinder cover? Are we talking about valve covers or similar on a four stroke? There is some spray that comes out pink to purple from an a spray can. It can be sprayed into the cap and put on as a liquid. High tack perhaps. used it up years ago. Norton mechanic liked that.
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    yes, I was wondering if you meant valve cover gasket? If so, I use Permatex Ultrablack on it. If it's the head gasket, I would hope that you are always using a fresh one and not using any sealant on it, unless the technical manual specifies that you do.:excuseme:
  4. Hwy Mini-Sponsor
    SF Bay Area
    It's called a "top cylinder cover" on a four stroke 510. Valve cover is the cover used for adjusting the valves. I suppose many call it a rocker cover.
    No gasket are used nor required for assembly.
  5. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    Gotcha, it's a single overhead cam design maybe? Anyway I've used Permatex Ultrablack and the grey colored Permatex gasket making RTV on those types of covers. Also have used it very successfully on the gasketless centercases of two stroke engines, as well a four stroke.
    http://www.permatex.com/products/Au...matex_Hi-Temp_RTV_Silicone_Gasket_Sealant.htm
  6. Hwy Mini-Sponsor
    SF Bay Area
    Thanks Dirtdame. I used the UltraCopper which is the same as UltraBlack but with a higher temp rating. Maybe it's my technique that's failing me.
  7. Husq.fleet Husqvarna
    Pendleton Oregon
    If it is a sealer only joint I use "right stuff", made I believe by permatex. Tough to get apart again though. Prep before with brakecleaner or acetone, one drop of oil or coolant and no seal.
  8. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    I've been using this product for years with great results.:thumbsup:
    It's recommended by Harley-Davidson® and we all know they need all the help they can get when it comes to stopping leaks.:lol::lol:
    Gasgacinch
    When dry you can pull on it like a rubber band. Applies like contact cement. Apply, let dry, stick together.
    It has a shelf life so make sure you get a new can and not one that's been on the shelf covered in dust.:D
  9. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    I'm still not clear which part is needing sealant. Is it what most of us would call the valve cover or something else? What bike are we working on? I know we're in the vintage side but still helpful for us numbskulls to know what you're talking about, lol.
  10. raisrx251 Husqvarna
    Virginia
    Honda has some really good stuff and it comes in two different styles. One is softer than the other when dry. I used this Honda brand on a two stroke cylinder instead of a gasket and was impressed with it.
  11. Hwy Mini-Sponsor
    SF Bay Area
    ya need a pic?:smirk:...look at the first post. It's call a "cylinder top cover" per the service manual.
    HuskyDude- Gasgcinch was my first choice but I can't find it around these parts.
  12. ioneater Husqvarna
    NW Texas
    2010 TXC 250
    08 Sprint
    Yes, I do. I don't know the vintage parts/lingo/quirks. If you saw service/parts manuals I deal with for a living you'd understand, maybe.
  13. Hwy Mini-Sponsor
    SF Bay Area
    I was waiting for the o-ring to arrive from MotoXotica. Brown Box truck arrived a few hours ago and I gave Yamabond another try. It's all buttoned up and I'll start the 510 tomorrow.
    We'll see if I sealed it this time. Don't know if I can stand another round off this!
  14. Husq.fleet Husqvarna
    Pendleton Oregon
    I re-read your post and if I understand it correct you are trying to seal a gasketless mating surfaces? If so and especially if they are dissimiliar material or just different sizes-expansion/contraction rates I would suggest this. Try a anerobic sealer from Permatex, I believe the number is 518. It flexes with flanges for example to provide a "o-ring" type of seal. Used alot when mating two alum. housings together in the automotive industry, also alum. to steel. Red jelly looking stuff that only dries in absence of air-anerobic. I use it instead of a gasket on my clutch covers and no leaks. I can verify that part number tomm. at the shop if you wish. Scott
  15. Hwy Mini-Sponsor
    SF Bay Area
    Scott-
    Yes, that's correct. Two machined flat aluminum surfaces together.
    Tolerance has to be in the thousands as the rocker arms reside in the top part and adjustment to valve lash has to be taken into consideration, hence no gasket.
    I'll see what the results are with this round. I did install a new o-ring this time to the camshaft cover. The previous one was used in the last two attempts.
    I would be interested in the Permatex item number.
    Thanks
  16. Husq.fleet Husqvarna
    Pendleton Oregon
    I have had great luck with it, Permatex part number is 51813, thats a pretty big tube and I'm sure you can buy a smaller tube. Above part number is around $25. I think you will be satisfied with the results. Easy clean up as it doesnt dry away from the actual joint. Scott
