Right the long and short of it i want a hydro clutch on my itallian 2002 360, now i have been tinkering with a magura one splicing the clutch cable joining it to slave going to actuator etc. Ive been thinking backwards, if i remove the actuator and mill the outter case where it goes flush, i can mount a ktm slave cylinder there and just push directly on the clutch rod going through the engine? Now my question is do the ktm slaves push or pull actuate? And if its a pull you think we can reverse the mechanism.? I dont mind welding or machining ali but i do mind totaling my only pair of engine cases. Once the actuator casting tube is off there is no going back.
