Who's Riding A Te510 (2010) Any Parts Availability Issues?
Discussion in '4 Stroke' started by DCrider, Feb 26, 2019.
  1. DCrider Husqvarna
    2010 TE510
    DRZ400S; R1150R, '72 Bonneville
    Newbie here, looking at buying a well set up, 1700mi, 2010 TE510 for DS riding around UT/CO area. I've done a lot of reading and found the "Living with a TE510" thread here which was very useful, http://www.cafehusky.com/threads/living-with-a-2010-husky-te-510.6249/. I'm close to pulling the trigger on this bike but have found little info that indicates if parts availability for a nearly 10yr old bike is much of an issue or not. Can anyone chime in on this for older Huskys?
    Thx, DCr
  2. rancher1 Husqvarna
    WA
    Parts still seem to be available.
  3. ghte Husqvarna
    Bright, Victoria Australia
    TE510 is a fantastic bush weapon. However I would question its real value as a genuine DS bike. The gearing is too low in 5th and 6th gears to make it fit for purpose. If you mean short bitumen connecting roads to fire trails etc the this will be fine. However a lot of tarmac is not in their design brief. I would go KTM 525/530 with their wide ratio box or for that matter a WR450.
    DCrider likes this.
  4. DCrider Husqvarna
    2010 TE510
    Yeah I hear you on the close gearing. It's frustrating at times that my DRZ400S does not like sustained pavement riding at much more than 60mph, and better to keep at 55, but you think the TE would be any worse than the 5-spd DRZ?
  5. ghte Husqvarna
    The 510 is superior in every respect to the DRZ 400, Lighter, better suspension and frame, Better brakes and a lot more power. (a bit more maintenance required as it is still a high performance bike). It will do similar speeds to the DRZ on tarmac but as indicated that is not its long suit.
    If you are keen on the DS idea I would do the following:
    Get a longer range tank
    Get a cush hub (or a least a cush sprocket)
    Put a 2 tooth smaller rear sprocket on
    Consider a recluse as well as this might help with the clutch work in the tight stuff given your higher gearing.
    Good luck and let us know what you decide.
    Cheers.
  6. DCrider Husqvarna
    2010 TE510
    Thanks ghte. Funny you should discuss sprockets as I just finished researching what others have used, you are spot on. The bike I'm looking at has stock tank and a 3gal IMS tank (though might need the 16L safari for extended DS trips), recluse, and up 1 tooth to 14 on front. I'm getting close to deciding, will def post here what I do.
  7. DCrider Husqvarna
    2010 TE510
    So I went for it, got it for $3k, hope she treats me right, can't wait to ride it.
  8. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    you have what's basically a SWM 500RS so many base engine and chassis parts will be common. FYI for future issues you may have.
    DCrider likes this.
  9. Darkside Husqvarna
    SF Bay Area
    none left
    beta, ktm, aprilia
    those are still good looking bikes. anyone notice how the new orange bikes are looking very similar in the shroud design?
    DCrider likes this.
