Why can't I get my bars straight?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Aviduser, Jun 1, 2013.
  1. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    I can't seem to align the handlebar mounts. I guess they must be effed. I haven't had any hard crashes just a few low speed dumps.
  2. proeasy Husqvarna
    SE Michigan
    TE-630, TE-510
    R1100 RT, XR-400R
    Are you using risers at all, they both need to be seated the same way, I had a similar till I found my mistake
  3. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    you're talking about how the risers are offset? They're both in the same orientation.
    Maybe I should reverse one to correct it :lol:
  4. Arctra Husqvarna
    Sydney
    Your forks may be twisted in the triple-clamp mounts. Loosen off the triple clam bolts holding the forks (just loosen them, not too much) then secure the front wheel and twist the bars in a jerking motion to get the forks/handlebars lined up properly. Once you're done, don't forget to re-tighten the triple clamp bolts so your forks are secure again.
    I've had to do this a few times after having high-speed get-offs. Quick and easy and a damned side cheaper than having to get new bars!
    duggoey and ray_ray like this.
  5. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    I agree and have tried that method. As you can see the mount's won't line up with the top triple clamp. I've loosened them and the fork pinch bolts then racked the bars.
    I've got it closer but it's still out. The bars only want to twist so much, then nothing. Maybe I should swap the handlebar mounts from either side and see if that changes things.
    Thanks for the advice.
  6. Boogie Husqvarna
    Australia
    Red head
    Take the top half of the handlebar clamp off and check if it is twisted. Place it on something flat to check.
    No matter how straight your fork, triple clamps and lower part of your handlebar clamps are... If the top is twisted, you'll never get your handlebars mounted straight.
    They are hard to re-straighten. Give it a go but buying a new one is much easier.
    K.Forte', Aviduser and Arctra like this.
  7. Arctra Husqvarna
    Sydney
    OK, I see what you mean now. Dunno if you know this but there are rubbers between the mounts and the triple clamps that allow the mounts to move a little. I damaged mine quite badly when I crashed and broke my collarbone - ended up getting aluminium bar mount bushings from BRP (http://www.brpmoto.com/products?pag...page.pbv.tpl&product_id=2125&category_id=1554) to replace them.
    What you might want to try first is inspecting them. If they look OK, then try loosening the bar mount bolts and again seeing if you can twist the bars to line up properly, then tightening them again. If the rubbers are stuffed though you might need to get some of these aluminium bushings to replace them and that will hopefully sort your problem out.
  8. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    Do you think those would fit an '08 cr 125/45mm zokes?
    I can't find anything wrong with the rubber inserts/handlebar clamps/or bars really. Somethings def. tweaked though. I can't really bring myself to believe the handlebar mounts would be twisted. They're pretty burly.
    But you could be right, looking at the pic the only logical answer seems to be that the mounts aren't seating right...
  9. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Have you looked to see if the mounting bolts are bent ?
    typeone likes this.
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    how badly do you notice this when riding? try get off the other side to straighten, if its no major bother i would be tempted to leave it, but definatly looks like the bar clamps twisted.
  11. bdl507 Husqvarna
    New Hampshire
    99 wr360
    rd350 dr650 tt500 pe250 hondas lots
    Take the two big bolts out of the clamps that hold them to the triple tree and take the bent one and put it in a vice. Now that its in a vice smash it with a hammer till straight. Very common issue or you can buy a new bolt. Most used bikes you buy will have hammer and vice marks on those bolts if you take them out.
    duggoey likes this.
  12. Boogie Husqvarna
    Australia
    Red head
    These pics are from an old post here: http://www.cafehusky.com/threads/2010-te250-power-up-and-protection-and-my-introduction.17845/page-2
    My top clamp plate was twisted similar to the pic below after a crash. I tried to straighten it but it was difficult. Check this plate and the mounting bolts.
    ray_ray, Indorider and Aviduser like this.
  13. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    I replaced the bolts no dice. I will check the top mounting clamp. Maybe I can swap to separate top caps if that's the issue. Makes sense I dunno why that didn't dawn on me. Thanks!
    Edit: yep that's it, twisted about as bad as the one in your picture
    Seemed to miss boogie's post but he was spot on as well
    Boogie likes this.
  14. Jhunter Husqvarna
    Atlanta
    Boogie nailed it. I had the same twist issue, twice. A quick fix it so take a hack saw and cut out the two center cross bars to that your two top clamps are independent of each other. Also double check to make sure your two bolts are not bent.
  15. Wolf Husqvarna
    Plantation, FL
    TC and FC 125/250
    Yes
    Yup, had the same issues. Cut the top clamp in half and all will be straight :)
  16. justpinit Husqvarna
    Maryland
    2012 wr 300
    93 kx 125 with a kdx 200 engine.
    Brp racing has aluminum inserts to replace the rubber ones in the top clamp. Do not cut the top bar clamp in half, the bars will twist easier. Its one piece for a reason. I used the brp inserts and drilled them to accept a bigger bolt. The head of the bolt didnt fit exactly, but it worked great! The top clamp is cheap $$ and adds strength.
  17. Wolf Husqvarna
    Plantation, FL
    TC and FC 125/250
    Yes
    We now use the BRP individual clamps with no ill effects. Cutting the top clamp worked just fine for us for months. The top clamp that comes stock is weak, we went through 4 of them, 3 without crashes, just hits.
  18. Sceep Husqvarna
    'Burque
    '09 te310
    '94 st1100
    god this has been driving my ass crazy on my dads wr250.
    just emailed him the pics. i'm betting thats the problem.
    thanks!!:cheers:
    Coffee likes this.
  19. justpinit Husqvarna
    Maryland
    2012 wr 300
    I must have done something different, when i cut the top clamp there was no strength left.
  20. Jhunter Husqvarna
    Atlanta
    I've been running with the center cross bars cut out of my top clamp for 3 years and have had plenty of crashes. I've tweaked the bars but a swift jab with the palm of your hand and they straighten up. I'll post a picture tonight.
    ray_ray and juicypips like this.
