All 2st Why is my bike a Pogo stick ???
Discussion in '2 Stroke' started by PJBlank916, Jun 8, 2016.
  1. PJBlank916 Husqvarna
    TE 300 (soon)
    2013 Crf 450r KDX 200 CRF 450X
    Hey guys last race I rode.my Wr 300 to a broken clutch cable 26th place in sportsman A and a sprained ankle and knee bike still ran two laps without a clutch !! Any way my rear suspension was bouncing my everywhere !! I have a spring from race tech correct for my weight (250) do I need to have it revolved ?? Thanks guys !!
  2. Scott Howard Husqvarna
    Victoria, BC, Canada
    FE350s, 701 enduro
    650 V-strom, Beta 300RR
    Sounds like there's no damping. Did the oil leak out? Probably needs a rebuild.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Could need a nitrogen re charge as that is what gives the damping aside from the oil.
    You may have your clickers on min settings.
    When did you last have the suspension sorted? If never well get it checked.
  4. lankydoug Husqvarna
    MO
    WR
    TM 300en
    My 09 wr250 did the same thing all at once and it was due to shock piston seal failure. Time for a shock rebuild and I had mine re-valved by LTR while it was apart.
    shawbagga likes this.
  5. PJBlank916 Husqvarna
    TE 300 (soon)
    Thanks guys I'm gonna give the guys at LTE a call and get a quote thanks for your help !
  6. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    My TE450 did the same thing a couple of years ago. And yup, I had a new o ring and piston sealing ring put in.
  7. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Yup wat DD n Doug said. Mine did it too. Was problem with earlier Sachs shocks thàt factory pretended wasn't happening(think ktm 2t starter!). Piston band too small n wen body gets hot oil bypasses it losing all rebound damping
