Will a 110 link chain fit? SM610
Discussion in '610/630' started by DirtyKid, Jun 4, 2014.
  1. DirtyKid Husqvarna
    Sm 610
    I despretly need to replace my chain on my 610 and ive been looking around and i cant seem the find the stock 112 link chain. the closest i can find is a 110 link chain and i dont know if it will fit. im assuming it would because there is a bit of room to move the wheel forward if i have to. i have a 15 tooth front sprocket and a 44 tooth rear sprocket.
  2. Circus Husqvarna
    San Diego
    I have a 2008 601SM. Stock is 15/45 with a 114 link chain.
    When I switched to a 16T front, with the standard 114 link chain I had to move the adjusters all the way forward and also use thinner jam nuts on the adjusters to get it to fit.
    Based on that, you are not going to make your 110 work. This is assuming that going from 15T front to 16T front is the same as increasing by a single link.
  3. DirtyKid Husqvarna
    Sm 610
    Ok thanks for the help. ill just keep looking.
  4. JonDirt Husqvarna
    London and NYC
    TE610 2008
    For my TE I bought a longer chain and then had the shop remove a couple of links... it was easy.
  5. bensl Husqvarna
    Australia
    te610, te310
    ducati diavel
    why dont you just buy a longer chain and cut it to fit?
    Kyle Tarry likes this.
