250-500cc Will a 93 wxc360 crank work on a 96 wxc250?
Discussion in '2 Stroke' started by Bansheerider29x, Dec 15, 2013.
  1. Bansheerider29x Husqvarna
    wxc250
    Just as the title states. I cannot for the life of me find a crankshaft/connecting rod for my 96 wxc250. The lower connecting rod bearing blew apart and the rod is seized to the crank. I been searching for a few weeks and have only found a 93 wxc360 crankshaft/rod for sale. Does anybody know what parts can be used from the 360 model on a 250 model?
  2. Travis Thompson Husqvarna
    1991 wxe 260
    1978 yamaha xs750 special
    Contact halls cycles. they were able to get me one for my 91 wxe 260 which is hard to find
  3. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    I'm pretty sure it won't. The 360 has a 73mm stroke, a much longer rod and huge flywheels.
  4. rancher1 Husqvarna
    WA
    The 360 has a longer stroke so your piston would come out the top. You could put a 360 top end on your motor and then you could use the 360 crank. The transmission and cases are the same on both bikes. A 93 and newer top end should work.
  5. Bansheerider29x Husqvarna
    wxc250
    ^^That would work for me. I can somewhat find wxc360 parts easier so far.
    Can i use my old reed cage and carb?And does anybody know if the power valve linkage is the same? Just would need a wxc360 cylinder, head, top end rebuild kit, crank and rod?
  6. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    It may require machining to get the crank to fit the cases. You'll have to use a 360 reed cage and manifold, but the carb can be jetted with 360 spec jets.
  7. rancher1 Husqvarna
    WA
    The engine cases are the same so no machining is required. The bikes use the same main bearings as well.
  8. Bansheerider29x Husqvarna
    wxc250
    Well that is good news! Bad news is i cannot find a 360 cylinder/head/reed cage. OR a 250 crank/rod. Whatever one i find first i will continue on the build.
  9. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    The 360 crank has a much bigger crank wheel diameter than the newer 250, so I wasn't sure.
    I have a '93 360 crank, top end with power valve linkage, reed cage and intake manifold from a motor I just robbed the 6 speed from. Just need new main bearings and a piston kit.
  10. Bansheerider29x Husqvarna
    wxc250
    Sent you a message Motorhead. Its either i buy your parts if its worth it or I send my crank out and pray its rebuild able.
