125-200cc Will crimped pipe hurt performance
Discussion in '2 Stroke' started by Pedec, Feb 3, 2016.
  1. Pedec Husqvarna
    Sask.Canada
    Just notice pipe is crimped will this affect performance. It ktm 200sx pipe on wr165. Did not notice any loss of power before taking bike apart. IMG_0303.JPG
  2. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Nope that's just fine tuning. When you punch a hole or taco it, then you'll see a difference.
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    THAT, PLEASE IF YOU DONT FEEL IT DONT SWEAT IT
  4. wallybean Mini-Sponsor
    Montana
    The header pipe is the most critical part of the pipe to keep uniform. That isn't a huge deformation but it is still costing you some performance. That will come out very easily by having someone blow it out. I fix simple issues like that all the time.
    juicypips likes this.
  5. Pedec Husqvarna
    Sask.Canada
    How do you blow it out.
  6. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    I would think it would have an effect. The repair process is not that easy if you dont have the right equipment. Its a process of sealing the ends and pressurising with an air compressor, you then gently heat the damaged part with a torch. It isnt recommended if you havent done it before or without someone helping who knows how. Im sure there are plenty of shops who can help you out up there.
  7. wallybean Mini-Sponsor
    Montana
    Yes it is better to have someone experienced doing the blowing out. It will take them at most 30 minutes to do a complete job. First they have to burn out the existing spooge and carbon build up. Then they plug the ends and pressurize the pipe somewhere between 30-50 psi works well. Heat up the affect area with a torch to a cherry red and the internal pressure causes the pipe to retake its original shape. This is over simplified and it is really easy to ffup. Some shops will use an inert gas so they don't have to heat up and blue the entire pipe. It also eliminates the worry of a possible "explosion". There is a 2" diameter hole in the wall of the shop 20 feet from the vise I was using when I had this happen when I first started doing this. Stained shorts and a shortened life also happened. The plug you use in the exhaust port flange of the pipe is still down there between the walls somewhere. Steep learning curve. Now that I have done literally hundreds of pipes it seems easy and straight forward.
    reveille, woodsrider and Xcuvator like this.
  8. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    not feeling any loss of power means that you don't ride to the max :busted:
    I know a bit about fluids and pipes and a deformation like that on that place has a big impact on how the media flows.
    Flows of fluids is not behaving much different then gasses (yet gases flow quicker (especially when they are hot))
    the flow would be disturbed considerably and different wave patterns will form.
    As the 2 stroke exhaust is one giant flute created to resonance in a bandwidth of rpm's the performance will be effected, yet it may be in a rpm range that you don't push your bike in.
    Robert-Jan
  9. Pedec Husqvarna
    Sask.Canada
    Looking like I need a new pipe.
  10. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    Those pipes aren't that easy to replace. If you think it's a problem, get it fixed.
  11. Pedec Husqvarna
    Sask.Canada
    Does anybody know somebody who can fix 2 stroke pipes in Canada.
  12. lankydoug Husqvarna
    MO
    WR
    TM 300en
  13. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    There are tons of people who do that in Canada. Ask some of your riding buddies. If one of them doesn't do it, I'm sure they'll know somebody
  14. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    wow without a blow off protection it can be hazardous
  15. everfree Husqvarna
    Bend, Oregon
    86 430AE (2), 88 430AE, 87 430WR (2)
    87 250 XC, 87 430 CR, '17 GG 300
    I watched this Motor Trend YouTube video where they bash header pipes and dyno the effects. I thought it would effect motor output more. Of course, it has 8 exhaust pipes vs. 1 pipe, but still interesting.
    View: https://www.youtube.com/watch?v=azPKIjxmmdU
  16. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    MXA did a dent test on 2t pipes some dents actually showed an increase on the dyno the dents where huge before they got a power loss :excuseme:
    everfree likes this.
  17. 2premo Husqvarna
    Northern NV
    pulse tuning is important
    that said pulse tuning for a wide RPM range means many compromises exist
    if you were tuning for one VERY specific RPM you would notice a tuning loss at that point
    but the modern off-road bike we are talking about lugs and revs, so the tuning of the pipe was never spot on anywhere
    mine will need to be fixed as it's bent enough to not fit correctly
  18. wallybean Mini-Sponsor
    Montana
    Here is a view from the vise and next to it is the hole through the particle board. I won't post pics of the shorts. Sometimes it is a wonder I have survived to this advanced age.
    The header pipe on the 165 is particularly important with the 200 SX pipe. It is also an easy fix as the only real issue is keeping the plug below 400 degrees working that close to the spigot.
  19. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Nice shootin' Tex!!!
    wallybean likes this.
  20. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I blew the inlet plug out on my first one and yeah it was exciting. I was nervous about it and didn't burn the spooge out first, so I wasn't anywhere close to the line of fire.
    Light tapping on the crease with a body hammer (much like straightening a body panel) also helps me to make some repairs invisible on un-plated pipes..
    duggoey and wallybean like this.
