250-500cc Will wr250 Motor Fully assembled drop into frame?
Discussion in '2 Stroke' started by Ozmoto, Jul 24, 2012.
  1. Ozmoto Husqvarna
    2006 Wr 250
    Hey guys,
    Quick question I stripped my 05 wr250 and sent the cylinder and bottom end off for repair.
    I am currently away for work and am arranging by distance the rest of the repairs.
    When I was pulling apart the bike I pulled the head off before I removed the engine from the frame.
    I want to know if I the motor can slide into the frame fully assembled? Problem being I'm not at home to measure the bike!
    If it does drop into the frame will make life easy as the shop is doing the bottom end, I could do the top end myself but for another $100 labour I could have her ready to drop in when I get home.
  2. cuprastic Husqvarna
    slovenia
    You can install fully assembled engine into frame, I ve done mine last winter!
  3. R_Little Husqvarna
    NJ
    Take the pipe off and it drops right in.
    it's a bit heavy so use a friend. get the swingarm axel in 1st.
  4. wallybean Mini-Sponsor
    Montana
    +1 to both above. I did it with my 360 too but that motor is at least 5 lbs heavier.
