Winter Maintenance
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Mercury264, Nov 30, 2008.
  1. Mercury264 Husqvarna
    Metrowest, MA
    Had a very enjoyable day on Friday blasting through the woods but I think that may well have been my last ride of the season.
    So....I need to figure out what maintenance to do over the winter.
    Here's my list so far:
    Definitely:
    Chain
    Sprockets
    Rear tire
    Check valve clearances
    Maybe:
    Swing arm bearings
    Forks - re-spring, new fork seal
    Steering head bearings
    Anything else I missed ? Should I do my maybe list ?
  2. Mike Kay Husqvarna
    California
    turn off the gas. run the bike until it stops running.
  3. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Why Put it away?
    Just keep riding.....:thumbsup:
    Here's a friend (Guy Perrett) do'n his thing on his Husky.
    Ya just gotta dress a little warmer.:D
  4. Mercury264 Husqvarna
    Metrowest, MA
    Sadly, that's not an option here in New England. I'd love to ride all year round and I can dress for the cold but the trails are either closed or not passable. I do ride my XRL on the road so I get my bike fix in but when the white stuff starts falling, it's time to ski :applause:
  5. Mercury264 Husqvarna
    Metrowest, MA
    Is there anything else I should be thinking of looking at/doing ? As per my sig, bike is an 06 TE450 that has about 1,700 miles on it. Mainly ridden on trails here in New England so it's had a fairly hard life so far.
    Water pump, oil pump ? Anything ?
  6. Coffee CH Owner
    At the risk of sounding like a smart alec - maybe update your profile with your location? I had no clue you were in the NE part of the country.
    I would do everything on your maybe list. If you have not had a re-valve then you could really be enjoying life in the spring time if that is in your budget (that would take care of the fork seals).
    You might want to consider putting the battery in a warmer climate than the garage.
  7. Mercury264 Husqvarna
    Metrowest, MA
    My bad Dean - I will update my profile.
    I plan on doing all the normal winterizing stuff (stabil in the gas tank, battery out and on a tender inside etc.) but I was just wondering if there were some things I should be considering doing given the age and usage of the bike.
