Wiring stock light kit wr300
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Flyin, Jun 21, 2009.
  1. Flyin Husqvarna
    Northern NJ
    WR 300
    I received my light kit in a box, with my new wr300.
    The only directions it had were to drill the holes for the tail light.
    Where can I find specific information on how to install this?
    I'm sure I can figure it out but I would like route the
    wires exactly as they were designed.
    Thanks
  2. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    I was in the same boat with my 300. There is a user on here who offered me assistance with assembling it and wiring it, but it was not a simple task.
    I ultimately ended up buying a TrailTech X2 light (pre assembled and far more powerful than the stocker:thumbsup:) and wired it in myself. I still have a box with a brand new headlight, taillight, computer and wiring harness sitting in it.
    This does not answer your question, but does give you an idea of an alternate option. And it bumps your thread back to the top :cheers:
  3. Flyin Husqvarna
    Northern NJ
    WR 300
    new pics
    I've pretty much got it all figured out, except a few things.
    The first pic is the stock "voltage rectifier".
    The second is a shot of the frame, the hole on the left
    is for the gas tank.
    The hole on the right is threaded, could this be for the ground?
    Third pic is the "resistance", I'm pretty sure this needs to connect
    to the first pic but I'm not sure how.
    The fourth pic is the harness that is included with the kit.
    Which some how connects to pic 1 and 2.
    BTW, the quotes are the names from the spare parts catalog.
    Spare Parts pdf
  4. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Maybe this will help.
  5. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    The Workshop manual had a LOT of instructions for different assemblies, including my Power up kit and Baja Designs tail light.
    I'm guessing the workshop manual for the WR 300 would have this stuff in it too.
  6. Flyin Husqvarna
    Northern NJ
    WR 300
    Where did you tap in for power, the yellow wire in pic 1?
  7. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Yep.
    Splice the power wire into the yellow lead as shown in pic one and then ground it to one of the regulator posts.
    I can post some pics later if you'd like.
  8. blamecanada Husqvarna
    Genelle, B.C. CANADA
    2012 WR 300
    2007 Harley- Ultra Classic
    Hey Flyin---You didn't happen to find any instruction for the light kit and digital speedo install did you?
    Going threw the same thing with my new 2012 WR 300. Kinda surprised that there never provided instructions just a box full of parts and pieces.
    I'm sure i'll figure it out eventually but rather see some paper on it.
