Works Connection Hour Meter - 14 TC250r
Discussion in '4 Stroke' started by Sebastian, May 7, 2016.
  1. Sebastian Husqvarna
    2015 TE300
    2015 KTM 300 Six Days
    Purchased a Works Connection Hour Meter,
    I have tried everything possible with wrapping this red cable and it simply wont register anything.
    Can anyone post a picture of where they have the wire wrapped and if it works, im going crazy.
  2. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    Take all the extra wire length of works connection hour meter and wrap it around the coil stick up top below the coil stick wire connector.
    Make sure when you wrap wire around coil stick, it is tight. Then run two passes of black electrical tap over it to secure.
    I think mine goes around the coil stick about 5 times.
  3. Sebastian Husqvarna
    2015 TE300
    Could you take a photograph?
  4. Jon Husqvarna
    Wisconsin
    14 TXC 310R
    mine is set up just like dartyppyt said. Mine was spotty with registering hours for the 1st 10ish hours and now its been flawless.
  5. Matthew525 Husqvarna
    New Berlin, WI
    2013 TXC 250R
    KTM 525, HONDA CRF150
