125-200cc wr 125 2006 throttle cable routing
Discussion in '2 Stroke' started by db-89, Feb 24, 2016.
  1. db-89 Husqvarna
    wr125
    4 honda's
    any one have a picture or diagram of how the throttle cable should be can propperly on a 125.iv a cable coming before a race this weekend and i was having snagging issues last weekend and need to know the corect way to route it
    thanks
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Normally up under tank follows frame and out beneath bar pad inbetween bar clamps then to lever.
    Make sure the cable doesnt snagg or pull on the tank when you put it back on.
    Zip tie it to the underside of frame.
    NCSteve and JAM like this.
  3. Down Under XC Husqvarna
    Melbourne, Australia
    XC250 83', WR250 87','XC150 10
    WR165 10, 83 KDX 250,
    And I have two, and one runs beneath bar pad and the other this side of it and throttle twisted backwards, both work well both have issues. Not a clear favourite and suggest the same for most bikes if handlebars stayed still !! I do shield mine around tank / pipe area though.
  4. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    I rerouted mine with Lectron and new cable like juicy says except mine goes between top engine brace. Lectron doesn't have the 90 degree nipple like the stock carb.
    shawbagga and juicypips like this.
  5. JAM Husqvarna
    South Carolina
    2012 WR144
    2017 Beta Xtrainer 300
    I just installed a new throttle cable and routed between the top engine brace as well- it's a stock Mikuni carb, then under tank, (front brake side) between bar clamps to housing.
  6. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Only problem is rotatin carb for adjustment with cable between head stays
  7. JAM Husqvarna
    South Carolina
    2012 WR144
    Good point. The cable if undone on the housing makes that easy, but to your point another step...
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Another step? Run the cable up above the head stay and along frame.
    Or don't adjust your carb.
  9. racemx904 Husqvarna
    owenton, ky
    2014 Beta 350RR & 1986 430XC
    I dont jet/rejet much.... I run mine between head stays up backbone on left side and behind the triple trees to the housing.....
    shawbagga likes this.
  10. JAM Husqvarna
    South Carolina
    2012 WR144
    I'm routed through he supports and can still rotate the carb to remove the slide, or access the bowl.
