125-200cc wr 125 in water
Discussion in '2 Stroke' started by zanol, Jun 3, 2009.
  1. zanol Husqvarna
    portugal
    I have a 2000 wr 125. yesterday fell into a river when passing a bridge and then tried to catch it and got a more.
    should I do? what should I disassemble?
  2. Motosportz CH Sponsor
    Pull the plug and flip the bike upside down and drain the motor. Change the oil and do the air filer. Ride.
  3. zanol Husqvarna
    portugal
    thanks very much, I will try...
  4. Fast1 Husqvarna
    Minneapolis, MN
    You need to get the engine running ASAP (right now) and get it up to normal operating temp to dry it out thoroughly otherwise you will have a lowerend full of rusted bearings that will plauge you with problems down the road.
  5. zanol Husqvarna
    portugal
    thanks fast1, I pull the water out and change the oil. at now the motor is stoped. Do you think have problem???
  6. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Do you mean that the motor won't turn even if you have the sparkplug out?
  7. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    The way I dried out a fellow riders bike was to:
    Remove the exhaust pipe and pour the water out of it.
    Remove the sparkplug and kick the kickstarter until no more water came out of the exhaust port and sparkplug hole.
    Remove stator cover and make sure no water was in there.
    Drain the float bowl of the carburetor to remove water.
    Drain the transmission of old oil and water and refill with new oil.
    Make sure that there is no water left in the gas tank.
    Put everything back together, and the motorcycle should be able to start in a normal fashion.
  8. Fast1 Husqvarna
    Minneapolis, MN
    If it is hydro-locked you need to remove the spark plug and then turn the engine over to expel the water.
    Time is important. The longer any water remains in the crankcase the more likely you will have a problem down the road with crank and rod end bearings. You need to get the engine started NOW.
    This is no different than a 2 stroke jet ski engine that has been submerged. While racing them if we didn't get the engine running the same day it hydro-locked or took on water it was almost inevitable that they would develop lower end bearing issues.
  9. zanol Husqvarna
    portugal
    my moto is runing very well, thanks for your precious help, without you I´m nothing!
  10. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    I'm glad you got it going.:thumbsup:
