250-500cc wr 250 bearings
Discussion in '2 Stroke' started by fredd, Jun 13, 2013.
  1. fredd Husqvarna
    PUERTO RICO
    2016 kx 450f
    1995 chopper
    which are the #for wheel bearings front and rear for a 2007 wr 250.example 6202 etc.
  2. ray_ray Mini-Sponsor
    The Philippines
    The parts manual for this bike will have the exact size of the bearings for the wheels in it and you can go to any bearings store and buy them ... Or just carry the old bearings to the store and they can match them up for you ...
    fredd likes this.
  3. misterkridered Husqvarna
    St. Catharines
    2007 WR250
    2000 Honda XR600R
    Front 2 x 61905-2RS (25x42x9)
    Rear 2 x 6005-2RS (25x47x12)
    1 x 63005-2RS1 (25x47x16) This one is bloody expensive if you buy good quality.
    Alternative is just to buy kit with seals and bearings which are shitty Chinese bearings but very much cheaper and just replace them more often.
    I think Pivot Works is better than All Balls.
    http://www.motosportzhusqvarna.com/Husqvarna WR,CR 250-300.htm
    mr_manny, fredd and razornpc like this.
  4. oneal Husqvarna
    uk
    1999 wr 250 returned home.
    07 TE 450 2005 TE 450 1999 CR 125
    I just go to my nearest bearing store and buy the best i can afford.
  5. Coffee CH Owner
    I noticed you created 2 identical threads but with 2 different prefixes.
    I went ahead and deleted the duplicate.
  6. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    think that should be 6905 for the front bearings.[2RS or ZZ]
    On the rear if you are jammed[bearing store closed or out of stock] on the wide bearing for the rear brake caliper side you can deal with it by using two 6005 and an inner race from a used front 6905 on the outside as a spacer, instead of the stock aluminum spacer
    fredd likes this.
  7. fredd Husqvarna
    PUERTO RICO
    2016 kx 450f
    1995 chopper
    thanks steadydirt, thats what im talking about good direct information.
  8. Coffee CH Owner
    I might be able to use some of your expertise here:
    http://www.cafehusky.com/threads/general-bearings-question-need-to-find-one.33749/
  9. cuprastic Husqvarna
    slovenia
    2RS means rubber sealed bearing on both sides, and ZZ means steel sealed bearing, I have ALL BALLS on dirt and supermoto wheels installed (2006 WR 250) and are good price/quality ratio.
    fredd likes this.
  10. misterkridered Husqvarna
    St. Catharines
    2007 WR250
    2000 Honda XR600R
    61905 and 6905 will both work as they are both 25mm x 42mm x 9mm. I was using the SKF 61905.
  11. steadydirt Husqvarna
    Ontario
    Pardon my
    Pardon my error. SKF- excellent bearings
    Coffee likes this.
  12. fredd Husqvarna
    PUERTO RICO
    2016 kx 450f
    1995 chopper
    no problem buddy
    Coffee likes this.
