250-500cc WR 250 NO 1ST? SHIFT BOLT? OR BLOWN 1ST
Discussion in '2 Stroke' started by husk99, Nov 18, 2014.
  1. husk99 Husqvarna
    1994 Huskvarna WXE/WXC250 or CR/WR
    Hi,
    I recently got a 95-98 WR 250 motor from my Husky dealer.
    It was used in a non motorbike application (eg. Buggy)
    It seems to be in neutral when shifted all the way down (sprocket free-spins).
    All of the other gears work, but sometimes it won't select,
    unless i go the other way first eg. Up then Down.
    Sometimes it won't select a few times in a row.
    I have not started it, yet. (was using kick start to turn motor while selecting)
    Does this seem like a loose shifter prawl bolt?
    I read many other examples of this causing similar problems.
    Otherwise, how likely is it that it has a blown 1st gear?
    Cheers
  2. rancher1 Husqvarna
    WA
    Probably not a shift star problem on that motor. Could be a bent shift fork. It would be worth pulling the large clutch cover and having a look at the shift mechanism though.
