250-500cc Wr 250 rod rebuild help
Discussion in '2 Stroke' started by roj0000, May 17, 2016.
  1. roj0000 Husqvarna
    Wr250
    XR250 RVF400
    Hi guys
    I have to replace my rod on my 08 wr250.
    Can someone please tell me what parts i need to order and if there are other things i should be doing at the same time as replacing the rod.
    I am doing a replate and new pistion at the same time. I am at the point now where i just want to make it 100%.
    The bike has done around 150 to 200 hours.
    Thanks
  2. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    2021 Sherco 300SE 2002 Honda CRF450
    If you are doing the rod, I'd do the bearing too. Replace the seals/gaskets in the case while it's split as well.
    Heath
  3. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    yep if you have it in that many pieces do it all look real close at the trans to bearing gears shift forks ect replace as needed then it will be 101% race ready:thumbsup:
  4. lankydoug Husqvarna
    MO
    WR
    TM 300en
