250-500cc WR 250 running problem
Discussion in '2 Stroke' started by Bwukki, Aug 3, 2015.
  1. Bwukki Husqvarna
    Finland
    WR 250
    Hi
    I have problem with my 2005 WR250. I can't seem to get it running right.
    I have messed around with carburetor and I can get it to rev pretty good when I adjust the air screw almost all the way closed but then it just barely idles for couple seconds after revving and even then it doesn't drop to idle just as fast as it should.
    And if I open the air screw so that it idles good then it doesn't drop revs like it should. They just stay really high and race around for like 10 seconds and after that it drops to idle like it should.
    Any ideas what could be the problem? I have tried the stock 430 and 400 main jets and 2nd and 3rd needle position. I'm not sure about pilot jet size. I have cleaned the carburetor all the way and made sure the jets are open.
  2. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    If the throttle hangs after reving, your pilot jet is too lean try a larger size, the general rule of thumb is if the air screw is over two turns adjusted either direction the pilot needs changing.
    Mains dont come into the range untill mid too half throttle.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    good jetting info juicypips
    if the bike has been sitting or if you don't run a fuel filter check for blockage in the pilot jet
    ray_ray likes this.
  4. Bwukki Husqvarna
    Finland
    WR 250
    Thanks guys, I checked the pilot jet, it seems to be size 35. It had little blockage and it got little better after cleaning it. Now I can get it to idle and rev without too much throttle hanging but it still takes couple second before idle settles. I also put in 400 main jet and needle on middle position. I guess I'll order size 40 pilot jet and see what happens.
  5. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    dunno bout the 250s but the 300s hang a little regardless of jetting i found. guess crank inertia/being bigger bore. it aint no 85/125!
  6. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    I have just a little experience being a new WR250 owner, but mine does it occasionally, but isn't a concern. I did the gas shutoff test and it shows the pilot jet is correct. Besides, the thing lugs so low and pulls so smooth I ain't messin with nothin! Good on ya shawbagga for pointing that out.
  7. lankydoug Husqvarna
    MO
    WR
    TM 300en
    If a 40 pilot doesn't fix it then look for a small air leak around the intake and reeds. Spraying carb cleaner around the reed block should not change the idle... if it does you have an air leak. It's best to use Honda CR250 reed block paper gaskets on the Husky reed block. My 09 WR250 was perfect with a 37.5 pilot but I've since switched to a Lectron and it's way better and trouble free in weather and altitude changes.
    Xcuvator likes this.
  8. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Shawry lies his 3hunny is perfect no hang or anything just clean tree eating ;) power.
    454x likes this.
  9. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    its been eating pine trees all last week juicy. cut in a 3.3km track next to where we parked the ute & included every downed tree log/stump/termite mound i could find. kids & dog loved marking it out(plus counts as family time:D) . brutal to ride all 1-3 gear. if u dont like logs youd hate it. sorry for derail back to it people.
    454x and juicypips like this.
  10. CCP Husqvarna
    NJ
    04 WR250 11 WR250
    If it's the Mikuni carb- check the slide. Mine was wearing out and sucking air. I could never get it adjusted correctly.
    Petar likes this.
  11. Bwukki Husqvarna
    Finland
    WR 250
    I managed to brake the cable holder from carburetor. Have to wait couple days to get new one. But new odd problem has occurred. It tends to foul plugs now. I have put around 25 hours total on this bike now and I think I didn't change the plug for the first 15 hours.
    Now I have burned through 5 plugs in 3 hours. Yesterday I rode for half and hour, it was fine, but when I tried to get going again today it started and died after couple seconds. Any idea why this is happening? Could it be plug cap?
    Plug doesn't seem to have any particular color, maybe the tip is a bit black. And the jetting is the same as before so I don't think thats the reason now. I'm using br8eg plugs.
  12. Bwukki Husqvarna
    Finland
    WR 250
    So I got the new cable holder and some jets. I'm now running with 40 pilot and 380 main. Bottom power got much better. Still doesn't drop revs straight trough but it is manageable. And plug lasted little longer, managed to ride about 2 hours with it. Now it seems like the tip is black so I guess I will lower the needle to 2nd clip. Hopefully this helps with the plug fouling...
  13. Bwukki Husqvarna
    Finland
    WR 250
    Lost compression today... Thought it was another plug fouling but now I can move kickstarter with my hand. I guess I'll start ripping engine apart tomorrow. Hopefully cylinder is ok. And atleast after that I will know that the running problem doesn't come from the engine itself.
