250-500cc WR 300 Bottom Triple Clamp
Discussion in '2 Stroke' started by RobNewy, Apr 8, 2011.
  1. RobNewy Husqvarna
    Australia
    Finally managed to wash my bike after stacking it 5 weeks ago, and fracturing L1 vertabrae, and popping a couple of ribs.
    As I had a bit of a look, I noticed this.
    Anyone now of any aftermarket bottom triple clamps, or even a full set that will fit the 50mm 'Zokes?
    Cheers
    Rob
  2. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    My mates WR360 was like that and he had to mill it down and tapped a high tensile bolt with a nylon cover...get it fixed asap as you will crush a radiator if the bike falls harshly on that side.
  3. RobNewy Husqvarna
    Australia
    Ohmy, I'm not going to ride it until I get a new clamp, Not really sure on drilling and tapping my clamp, as it may weaken it.
    Camstyn, I like the Xtrig one, looks horn. Can't find any prices though
  4. racerjak Husqvarna
    Wallingford, Connecticut
    FC 450 Rockstar - 15 FE 501
    BMW Boxercup, BMW k1600gt
    BRP makes a real nice set. uppers and lowers. I have a set on my 250. No more flexing!!
  5. racerjak Husqvarna
    and yes, they do have them for 50mm Zokes.
  6. RobNewy Husqvarna
    Australia
    I have emailed BRP to see if the have the set for the 50mm Zokes.
    Only 30 bucks dearer for the 2, than for the OEM lower!
  7. joker Husqvarna
    OEM prices are really expensive, I always check for alternatives. BRP clamps will look great as well, worth the $30 extra. you didn't damage anything else on your bike? sounds like you came off worse than your bike, nasty injuries, hope you heal well.
  8. ohmygewd Husqvarna
    Aprilia RSV1000
    If you tap a course thread M5 through the stop and a nyloc underneath, you won't weaken the lower bracket as thats a big lump of casting. The trick is to have a rubber washer to absorb some of the shock - worst thing it will do is snap the head of off the allen head?
    Also, you could tap an M5 into that lug (but not all the way through) and have a welder run an aluminum weld around it?
  9. timpjr Husqvarna
    Sparks, NV
    93 WXC 360
    EVT America 3000w Scooter
  10. Dirt_drifter Husqvarna
    Sydney, Australia
    This happened to my 09 wr250. Very poor design imo.
    I was going to tap bolts in as well but i went for the easy option of just tacking on another piece of steel onto the standard steering stop to bring the height down. I could do this because my steering stops still has enough alloy on them. Had a few stacks since and so far so good.
  11. fran...k. Husqvarna
    eastern ct
    That kind of thing happens on street bikes also. I have a picture below of what I did to my 1998 wr 125 for a fork swap. You would have to decide for yourself if the clamps have enough material to keep from punching through and damaging the fork. I think for my 1998 which had conventional forks and a lower clamp which went up for more travel and wasn't straight across like the modern stuff the type of stop which breaks is really the only realistic option.
  12. RobNewy Husqvarna
    Australia
    Thanks for all the info. Much appreciated. That Fast by Ferraci, have some for my forks for 260US, not sure what postage will be but.
    I recieved an email from BRP, and they only do a top triple, so that is no good.
    I may just tap a bolt through it for now till I get some spare funds.
    This is my stack anyway, I was just tooling around as I hadn't ridden for a few months.
  13. ohmygewd Husqvarna
    Aprilia RSV1000
    **** mate that's got to hurt Where abouts in Melbourne are ya (I'm Sydenham way)?
  14. RobNewy Husqvarna
    Australia
    Yeah, it hurt like all hell.
    I'm at Ringwood North.
    Do you ride out Wombat way?
  15. ohmygewd Husqvarna
    Aprilia RSV1000
    Sure do mate, up at Cobaw as well and regularly at Dissa/Tallarook/Kinglake....big river to Tanjil is nice but it's a fair hike for me for a day trip - then again so is Anglesea.
